Home » Modeling » GMF (Graphical Modeling Framework) » AbstractBorderedShapeEditPart with LabelEditPart and ShapeNodeEditPart as a child
AbstractBorderedShapeEditPart with LabelEditPart and ShapeNodeEditPart as a child [message #204090] Mon, 01 September 2008 10:56 Go to next message
Originally posted by: blaent.gmx.de
I use a parent node (xy layout) with a label and children nodes (no
compartment mapping just child references).
If the diagram label is internal everything is alright.
But if it's declared external all added children will be expanded to
parent's size like using stack layout. Is this a bug or do I something
wrong?
Any help is appreciated.
Markus
Re: AbstractBorderedShapeEditPart with LabelEditPart and ShapeNodeEditPartas a child [message #204876 is a reply to message #204090] Tue, 09 September 2008 12:38 Go to previous message
Hello Markus,
Looks like a bug. You can try using compartment for inner elements with "listLayout"
property set to false for the corresponding GenCompartment element in .gmfgen
model as a workaround..
Alex Shatalin
Previous Topic:About property sheet of GMF
Next Topic:Grouping of objects
Current Time: Mon Nov 10 05:06:42 EST 2025
Powered by FUDForum. Page generated in 0.02515 seconds
