Home » Eclipse Projects » GEF » custom zooming and screen resolution
custom zooming and screen resolution [message #204038] Tue, 29 November 2005 17:17 Go to next message
Originally posted by: clmind.yahoo.com
I need some advice for some zoom implementation details... Basically, I have
my model coordinate system (measured in "units"), and the Eclipse coordinate
system (measured in 'pixels'). Units are about 15x smaller than pixels at
96 dpi and 12x smaller at 120 dpi, two common screen resolutions. To do
this, I'm using ZoomManager's UIMultiplier setting to make 100% actually
render at 1/15th the size so it's as if I'm rendering in pixels (and things
look the right size)
Here are the questions:
1. Is there an event I can hook into in Eclipse to update the ZoomManager's
UIMultiplier when the screen resolution changes?
2. Is there a "proper" way to have text rendered properly when a UI
multiplier is used, (hopefully without having to do another pixel-unit
conversion)? My non-text objects look correct because the ZoomManager takes
care of coordinate-related stuff; however, the font size used for text
rendering is affected by this as well, so I end up with text rendered at
1/15th the size it should be.
Chris
Re: custom zooming and screen resolution [message #204211 is a reply to message #204038] Thu, 01 December 2005 00:22 Go to previous message
You pretty much just have to take the Control's default font, and scale it
by the UI multipler.
When the resolution changes, the DPI does not necessarily change. I think,
if you change the DPI setting for windows, it usually asks you to reboot. It
affect all of the system fonts.
"Christine Lee" <clmind@yahoo.com> wrote in message
news:dmik2s$boa$1@news.eclipse.org...
> Hi
> have
> coordinate
> things
> ZoomManager's
> takes
> Chris
Previous Topic:EMF using GEF: link EObjects to editParts
Next Topic:Keyboard accessibility questions
Current Time: Wed Nov 05 05:06:18 EST 2025
Powered by FUDForum. Page generated in 0.02930 seconds
