| Re: XSD v1.0.2 -- Undesired Messages [message #19736 is a reply to message #19691] |
Fri, 02 May 2003 22:50  |
Originally posted by: paechoi.earthlink.net
Ed,
It's my fault. It is referencing the old version, 1.0.1, in my script.
After I changed that to v1.0.2, the problem is gone. Thank you.
Pae
P.S.: Although it seems working with v1.0.2, but breaking the code
when I just tested with v1.1.0. I will have to test it more before I
make any comment on that.
"Ed Merks" <merks@ca.ibm.com> wrote in message
news:3EB261D0.9C3C6F1F@ca.ibm.com...
> Pae,
> This looks like some old debugging messages, but I can't reproduce it and
I
> don't see anything like that in the current code base. What driver does
this
> happen with?
> Pae Choi wrote:
> > When I was creating an instance of XML Schema(XS) by using
> > the org.eclipse.xsd.XSDSchema.setDocument() from the DOM
> > using the org.w3c.dom.Document interface all seems well
> > except an unwanted messages as follows:
> > // ########## The unwanted messages ############
> > qNamePrefixToNamespaceMap.put(): start
> > key: [xsd] and value: [http://www.w3.org/2001/XMLSchema]
> > key: [xs] and value: [http://www.w3.org/2001/XMLSchema]
> > key: [hfp] and value:
[http://www.w3.org/2001/XMLSchema-hasFacetAndProperty]
> > key: [null] and value: [http://www.w3.org/2001/XMLSchema]
> > key: [xsi] and value: [http://www.w3.org/2001/XMLSchema-instance]
> > I think those message came out after the setElement() method
> > which inherited from the org.eclipse.xsd.XSDConcreteComponent
> > interface.
> > What is happening here and how can we turn them off?
> > Any comments?
> > Pae
| Re: XSD v1.0.2 -- Undesired Messages [message #569159 is a reply to message #19691] |
Ed,
Pae
> Pae,
I
this
> happen with?
> > interface.
> > Any comments?
> > Pae
FUDForum. Page generated in 0.04226 seconds
