Home » Newcomers » Newcomers » Code stops working on new Eclipse install!
Code stops working on new Eclipse install! [message #203883] Sat, 07 April 2007 21:43 Go to next message
Originally posted by: shasan.email.unc.edu
I've been using Eclipse on my Windows system for a while now with no
problems. However, when I moved to Linux, suddenly code that compiled just
fine before no longer compiles!
The problem happens anytime I use String.format or printf... Does anyone
know why this would happen? I'm guessing the Java SDK Eclipse is using is
not up to date... how can I check what version it's using?
Help is appreciated!
Re: Code stops working on new Eclipse install! [message #203898 is a reply to message #203883] Sun, 08 April 2007 01:40 Go to previous message
Originally posted by: wharley.bea.com
"ShaddI Hasan" <shasan@email.unc.edu> wrote in message
news:8f8fcaa64f2e37c322034e99b69ae727$1@www.eclipse.org...
I'm guessing that you changed workspace preferences and you no longer have
Java 5 or higher as your default compiler compliance setting.
Previous Topic:how to display .htaccess files on left?
Next Topic:eclipse crash on new project wizard
Current Time: Mon Sep 01 00:27:56 EDT 2025
Powered by FUDForum. Page generated in 0.07299 seconds
