Home » Eclipse Projects » GEF » PluginTransfer Drag and Drop
PluginTransfer Drag and Drop [message #203858] Mon, 28 November 2005 11:45 Go to next message
Originally posted by: apara.sharma.tugulu.com
I am working on Drag ad drop in GEF.
To drag i am using a PluginTransfer to transfer from NavigatorView to
Editor since they are different plugins in the application.
Using Plugin i am able to drag and drop between different plugins. THE
PROBLEM IS but i am UNABLE to implement drop in the same navigatorView.
Is there a way i can use Plugin transefer and do D&D in the same viewer.
I am in bad need of any kind of help.
Please suggest :)
Thanks and cheers
Apara
Re: PluginTransfer Drag and Drop [message #204135 is a reply to message #203858] Wed, 30 November 2005 08:59 Go to previous messageGo to next message
Originally posted by: ayesha.ltp.soft.net
You will have to write a class that extends
AbstractTransferDropTargetListener. Within this class, you must implement
the required methods.
Ayesha
"apara sharma" <apara.sharma@tugulu.com> wrote in message
news:dmfc7q$djh$1@news.eclipse.org...
> Please suggest :)
> Thanks and cheers
> Apara
Re: PluginTransfer Drag and Drop [message #204248 is a reply to message #204135] Thu, 01 December 2005 10:57 Go to previous message
D Ayesha ,
i extended PluginDropAdapter class and its works fine for me.
Thank u!!!
> Ayesha
>>Hi,
>>Please suggest :)
>>Thanks and cheers
>>Apara
Previous Topic:Keyboard accessibility questions
Next Topic:Generic Image Export
Current Time: Sat Nov 08 23:35:56 EST 2025
Powered by FUDForum. Page generated in 0.03024 seconds
