Home » Eclipse Projects » Eclipse Platform » Search across projects
Search across projects [message #203807] Sun, 29 February 2004 20:08
If one wants to rename a method that is being called in more than one
workspace project, what is the course of action? In my installation (M7)
Refactor->Rename can only find references in a single project (where a
method is declared). I tried reference searching instead and it does not
find references across projects either. Then I tried searching using
declared working set. No luck again.
The only way that I was at least able to find all method references is
when I use java search on a method name withouth declared parameters.
What I am doing wrong?
Vladimir
Previous Topic:eclipse using linux
Next Topic:is the baseTOCS preference gone?
Current Time: Sun Jul 27 11:06:03 EDT 2025
Powered by FUDForum. Page generated in 0.23599 seconds
