Home » Language IDEs » Java Development Tools (JDT) » M7: Ant Error
M7: Ant Error [message #203649] Mon, 16 May 2005 15:47 Go to next message
Just installed M7.
Now anytime I try to run a task from the ant view, I get a Virtual
Machine Launcher error msg saying: "Cannot find main class. program will
exit"
Any ideas why this would happen?
- Jonathan
Re: Ant Error [message #203656 is a reply to message #203649] Mon, 16 May 2005 15:52 Go to previous messageGo to next message
Is it only when you attempt to build from the Ant view?
Is it for all build files?
Any other indications of problems in the .log file?
How did you install M7...clean install or over a previous Eclipse install?
If you right click in the Ant view>Run As>Ant Build... to bring up the
launch configuration dialog is there indication of error in the dialog?
Darins
"Jonathan" <jonathan@sysbliss.com> wrote in message
news:d6atuu$oe6$1@news.eclipse.org...
> Just installed M7.
> exit"
> - Jonathan
Re: Ant Error [message #203669 is a reply to message #203656] Mon, 16 May 2005 16:04 Go to previous messageGo to next message
Installed M7 by renaming c:\program files\eclipse to c:\program
files\eclipse3.1M6 and then extracting the M7 zip to c:\program
files\eclipse (clean install)
I get the same error for ALL build files.
I get the error if I use the run task button in ant view, right clicking
and choosing run task in ant view, or from the run as... dialog.
Basically anytime ant is run.
The run as... dialog shows no configuration errors.
If I boot up the old M6 install (using same workspace) everything runs fine.
There are no errors put into the eclipse error log.
- Jonathan
> Darins
>>Just installed M7.
>>exit"
>>- Jonathan
Re: Ant Error [message #203683 is a reply to message #203669] Mon, 16 May 2005 19:45 Go to previous messageGo to next message
After attempting to run your Ant build, open the Debug view.
Right click on the process>Properties>Process Information.
Can you paste what it is indicated?
Darins
news:d6auvt$ppo$1@news.eclipse.org...
> and choosing run task in ant view, or from the run as... dialog. Basically
> anytime ant is run.
> fine.
> - Jonathan
>> install?
>> Darins
>>>Just installed M7.
>>>exit"
>>>- Jonathan
Re: Ant Error [message #203793 is a reply to message #203683] Tue, 17 May 2005 11:29 Go to previous messageGo to next message
Here it is.
I did notice that the -Djava.library.path looks a little strange cause
even the -D is included in quotes... not sure if that matters though
C:\jdk1.5\bin\javaw.exe -Dant.home=C:\apache-ant-1.6.2
-Dant.library.dir=C:\apache-ant-1.6.2\lib
" -Djava.library.path=C:\jdk1.5\bin;.;C:\WINDOWS\system32;C:\W INDOWS;C:\Perl\bin\;C:\WINDOWS\system32;C:\WINDOWS;C:\jdk1.5 \bin;C:\apache-ant-1.6.2\bin;c:\Program
Files\eclipse\configuration\org.eclipse.osgi\bundles\60\1\.c p "
-classpath
" C:\apache-ant-1.6.2\lib\Tidy.jar;C:\apache-ant-1.6.2\lib\ant -antlr.jar;C:\apache-ant-1.6.2\lib\ant-apache-bcel.jar;C:\ap ache-ant-1.6.2\lib\ant-apache-bsf.jar;C:\apache-ant-1.6.2\li b\ant-apache-log4j.jar;C:\apache-ant-1.6.2\lib\ant-apache-or o.jar;C:\apache-ant-1.6.2\lib\ant-apache-regexp.jar;C:\apach e-ant-1.6.2\lib\ant-apache-resolver.jar;C:\apache-ant-1.6.2\ lib\ant-commons-logging.jar;C:\apache-ant-1.6.2\lib\ant-comm ons-net.jar;C:\apache-ant-1.6.2\lib\ant-contrib-1.0b1.jar;C: \apache-ant-1.6.2\lib\ant-icontract.jar;C:\apache-ant-1.6.2\ lib\ant-jai.jar;C:\apache-ant-1.6.2\lib\ant-javamail.jar;C:\ apache-ant-1.6.2\lib\ant-jdepend.jar;C:\apache-ant-1.6.2\lib \ant-jmf.jar;C:\apache-ant-1.6.2\lib\ant-jsch.jar;C:\apache- ant-1.6.2\lib\ant-junit.jar;C:\apache-ant-1.6.2\lib\ant-laun cher.jar;C:\apache-ant-1.6.2\lib\ant-netrexx.jar;C:\apache-a nt-1.6.2\lib\ant-nodeps.jar;C:\apache-ant-1.6.2\lib\ant-star team.jar;C:\apache-ant-1.6.2\lib\ant-stylebook.jar;C:\apache -ant-1.6.2\lib\ant-swing.jar
;C:\apache-ant-1.6.2\lib\ant-trax.jar;C:\apache-ant-1.6.2\li b\ant-vaj.jar;C:\apache-ant-1.6.2\lib\ant-weblogic.jar;C:\ap ache-ant-1.6.2\lib\ant-xalan1.jar;C:\apache-ant-1.6.2\lib\an t-xslp.jar;C:\apache-ant-1.6.2\lib\ant.jar;C:\apache-ant-1.6 .2\lib\commons-collections-3.1.jar;C:\apache-ant-1.6.2\lib\c ommons-configuration-1.0-rc2.jar;C:\apache-ant-1.6.2\lib\com mons-io-1.0.jar;C:\apache-ant-1.6.2\lib\commons-lang-2.0.jar ;C:\apache-ant-1.6.2\lib\commons-logging-api.jar;C:\apache-a nt-1.6.2\lib\commons-logging.jar;C:\apache-ant-1.6.2\lib\com mons-net-1.3.0.jar;C:\apache-ant-1.6.2\lib\junit.jar;C:\apac he-ant-1.6.2\lib\log4j-core.jar;C:\apache-ant-1.6.2\lib\log4 j.jar;C:\apache-ant-1.6.2\lib\vsd_ant_tasks.jar;C:\apache-an t-1.6.2\lib\xercesImpl.jar;C:\apache-ant-1.6.2\lib\xml-apis. jar;C:\Program
Files\eclipse\configuration\org.eclipse.osgi\bundles\8\1\.cp \lib\remoteAnt.jar;C:\jdk1.5\lib\tools.jar;C:\Program
Files\eclipse\plugins\org.eclipse.swt.win32.win32.x86_3.1.0. jar "
org.eclipse.ant.internal.ui.antsupport.InternalAntRunner
"\"-Declipse.connect.port=1443 \""
"\"-Dorg.eclipse.ant.core.ANT_PROCESS_ID=1116343090993 \"" "\" \""
"\"-Dbasedir=C:\data\eclipse\workspace\ActorsWeb \""
\"-Dant.home=C:\apache-ant-1.6.2\" -logger
org.eclipse.ant.internal.ui.antsupport.logger.RemoteAntBuild Logger
-inputhandler
org.eclipse.ant.internal.ui.antsupport.inputhandler.ProxyInp utHandler
-buildfile \"C:\data\eclipse\workspace\ActorsWeb\build.xml\"
- Jonathan
> Darins
>>anytime ant is run.
>>fine.
>>- Jonathan
>>>install?
>>>Darins
>>>>Just installed M7.
>>>>exit"
>>>>- Jonathan
Re: Ant Error (fixed) [message #203808 is a reply to message #203793] Tue, 17 May 2005 12:28 Go to previous messageGo to next message
OK, i got the issue fixed.
Basically, eclipse is now including the env PATH var as part of the
java.library.path This is fine except that in my env PATH I had quotes
around an entry that contained spaces (namely "C:\Program
Files\Microsoft Visual Studio\VSS\win32"; go figure.)
eclipse didn't escape the quotes properly and that made it go boom.
I just took off the quotes in my env var and everything runs fine now.
I'm not sure if this would really be considered a bug or not seeing as
how most people would put quotes in their path var.
Thanks for the help!
- Jonathan
Jonathan wrote:
> Here it is.
> -classpath
ar
> -inputhandler
> - Jonathan
>> Darins
>>> clicking and choosing run task in ant view, or from the run as...
>>> dialog. Basically anytime ant is run.
>>> runs fine.
>>> - Jonathan
>>>> install?
>>>> Darins
>>>>> Just installed M7.
>>>>> will
>>>>> exit"
>>>>> - Jonathan
Re: Ant Error [message #203816 is a reply to message #203793] Tue, 17 May 2005 12:28 Go to previous messageGo to next message
So it would appear that you have modified the Ant runtime classpath to point
to an external Ant home: C:\apache-ant-1.6.2?
M7 ships with Ant 1.6.3 as an Eclipse plugin.
That said things should still work...but your Ant runtime classpath will not
be automatically upgraded if you as the user have made changes.
The path element of interest is: C:\Program
ar
Does this actually exist? This is the Eclipse Ant integration jar that
provides the entry point for running Ant
I will try to reproduce the problem with having the Eclipse install in a
location with spaces...possibly a bug.
Thanks for your help in tracking this down
Darins
news:d6d2lk$6cp$1@news.eclipse.org...
> Here it is.
bin\;C:\WINDOWS\system32;C:\WINDOWS;C:\jdk1.5\bin;C:\apache- ant-1.6.2\bin;c:
\Program
> -classpath
pache-ant-1.6.2\lib\ant-apache-bcel.jar;C:\apache-ant-1.6.2\ lib\ant-apache-b
sf.jar;C:\apache-ant-1.6.2\lib\ant-apache-log4j.jar;C:\apach e-ant-1.6.2\lib\
ant-apache-oro.jar;C:\apache-ant-1.6.2\lib\ant-apache-regexp .jar;C:\apache-a
nt-1.6.2\lib\ant-apache-resolver.jar;C:\apache-ant-1.6.2\lib \ant-commons-log
ging.jar;C:\apache-ant-1.6.2\lib\ant-commons-net.jar;C:\apac he-ant-1.6.2\lib
\ant-contrib-1.0b1.jar;C:\apache-ant-1.6.2\lib\ant-icontract .jar;C:\apache-a
nt-1.6.2\lib\ant-jai.jar;C:\apache-ant-1.6.2\lib\ant-javamai l.jar;C:\apache-
ant-1.6.2\lib\ant-jdepend.jar;C:\apache-ant-1.6.2\lib\ant-jm f.jar;C:\apache-
ant-1.6.2\lib\ant-jsch.jar;C:\apache-ant-1.6.2\lib\ant-junit .jar;C:\apache-a
nt-1.6.2\lib\ant-launcher.jar;C:\apache-ant-1.6.2\lib\ant-ne trexx.jar;C:\apa
che-ant-1.6.2\lib\ant-nodeps.jar;C:\apache-ant-1.6.2\lib\ant -starteam.jar;C:
\apache-ant-1.6.2\lib\ant-stylebook.jar;C:\apache-ant-1.6.2\ lib\ant-swing.ja
r
\apache-ant-1.6.2\lib\ant-weblogic.jar;C:\apache-ant-1.6.2\l ib\ant-xalan1.ja
r;C:\apache-ant-1.6.2\lib\ant-xslp.jar;C:\apache-ant-1.6.2\l ib\ant.jar;C:\ap
ache-ant-1.6.2\lib\commons-collections-3.1.jar;C:\apache-ant -1.6.2\lib\commo
ns-configuration-1.0-rc2.jar;C:\apache-ant-1.6.2\lib\commons -io-1.0.jar;C:\a
pache-ant-1.6.2\lib\commons-lang-2.0.jar;C:\apache-ant-1.6.2 \lib\commons-log
ging-api.jar;C:\apache-ant-1.6.2\lib\commons-logging.jar;C:\ apache-ant-1.6.2
\lib\commons-net-1.3.0.jar;C:\apache-ant-1.6.2\lib\junit.jar ;C:\apache-ant-1
..6.2\lib\log4j-core.jar;C:\apache-ant-1.6.2\lib\log4j.jar;C :\apache-ant-1.6.
2\lib\vsd_ant_tasks.jar;C:\apache-ant-1.6.2\lib\xercesImpl.j ar;C:\apache-ant
-1.6.2\lib\xml-apis.jar;C:\Program
> -inputhandler
> - Jonathan
> > Darins
Basically
> >>anytime ant is run.
> >>fine.
> >>- Jonathan
> >>>install?
> >>>Darins
> >>>>Just installed M7.
will
> >>>>exit"
> >>>>- Jonathan
Re: Ant Error (fixed) [message #203824 is a reply to message #203808] Tue, 17 May 2005 12:33 Go to previous messageGo to next message
Jonathan,
Can you please log this issue as a bug report
Darins
news:d6d641$b1e$1@news.eclipse.org...
> - Jonathan
> Jonathan wrote:
> > Here it is.
\Program
> > -classpath
> ar
> > -inputhandler
> > - Jonathan
> >> Darins
> >>> runs fine.
> >>> - Jonathan
> >>>> install?
the
dialog?
> >>>> Darins
> >>>>> Just installed M7.
> >>>>> will
> >>>>> exit"
> >>>>> - Jonathan
Re: Ant Error (fixed) [message #203862 is a reply to message #203824] Tue, 17 May 2005 13:25 Go to previous messageGo to next message
logged. bug id: 95611
Thanks!
- Jonathan
> Jonathan,
> Thanks
> Darins
>>- Jonathan
>>Jonathan wrote:
>>>Here it is.
> \Program
>>>-classpath
>>ar
> .6.2\lib\log4j-core.jar;C:\apache-ant-1.6.2\lib\log4j.jar;C: \apache-ant-1.6.
>>>-inputhandler
>>>- Jonathan
>>>>Darins
>>>>>runs fine.
>>>>>- Jonathan
>>>>>>install?
> the
> dialog?
>>>>>>Darins
>>>>>>>Just installed M7.
>>>>>>>will
>>>>>>>exit"
>>>>>>>- Jonathan
Re: Ant Error (fixed) [message #203887 is a reply to message #203862] Tue, 17 May 2005 14:17 Go to previous messageGo to next message
Thanks to Jonathan's help we have fixed this up.
To workaround in M7, you can turn off "Set an Input Hander" on the Main tab
of your Ant launch configuration.
I now have a quoted path on one of my machines to catch these problems in
the future :-)
Darins
news:d6d9f1$eu2$1@news.eclipse.org...
> Thanks!
> - Jonathan
> > Jonathan,
> > Thanks
> > Darins
> >>- Jonathan
> >>Jonathan wrote:
> >>>Here it is.
> > \Program
> >>>-classpath
> >>ar
> >>>-inputhandler
> >>>- Jonathan
> >>>>Darins
> >>>>>runs fine.
> >>>>>- Jonathan
> >>>>>>install?
> > the
> > dialog?
> >>>>>>Darins
> >>>>>>>Just installed M7.
> >>>>>>>will
> >>>>>>>exit"
> >>>>>>>- Jonathan
Re: Ant Error (fixed) [message #203896 is a reply to message #203887] Tue, 17 May 2005 14:20 Go to previous message
WoW! that was quick!
Thanks for taking care of it... sorry for messing up your path. :)
> the future :-)
> Darins
>>Thanks!
>>- Jonathan
>>>Jonathan,
>>>Thanks
>>>Darins
>>>>- Jonathan
>>>>Jonathan wrote:
>>>>>Here it is.
>>>\Program
>>>>>-classpath
>>>>ar
>>>>>-inputhandler
>>>>>- Jonathan
>>>>>>Darins
>>>>>>>runs fine.
>>>>>>>- Jonathan
>>>>>>>>install?
>>>the
>>>dialog?
>>>>>>>>Darins
>>>>>>>>>Just installed M7.
>>>>>>>>>will
>>>>>>>>>exit"
>>>>>>>>>- Jonathan
Previous Topic:how do I?
Next Topic:How to add JAR creation to the build chain (builder) ?
Current Time: Tue Nov 04 23:13:53 EST 2025
Powered by FUDForum. Page generated in 0.05531 seconds
