Re: The design file FILE_NAME has error and can not be run. [message #204609 is a reply to message #203387] |
Mon, 04 December 2006 04:53  |
Hi John, tnx 4 your reply. I'm using a MySql DB via JDBC driver. I'm not
using scripting or java objects in my report. It's a simple report just to
know if it works! My BIRT Runtime version is 2.1.1, while BIRT Designer
version is 2.2.0. My Java version is JDK 1.5.0.
Tnx a lot John!
We need a little more information. What type of data connection are you
using? Oracle, MySQL, flat file? Are you using any scripting or Java
objects in your report? What version of BIRT are you using? What version
of Java?
John
FUDForum. Page generated in 0.03181 seconds
