Home » Language IDEs » C / C++ IDE (CDT) » Eclipse Europa just stopped working!
Eclipse Europa just stopped working! [message #203074] |
Thu, 18 October 2007 14:14  |
I was trying the Europa version and it was working fine but from one
moment to another it just stopped working. It doesn't start with the
following message:
# An unexpected error has been detected by Java Runtime Environment:
# SIGSEGV (0xb) at pc=0x06217416, pid=12492, tid=3076466368
# Java VM: Java HotSpot(TM) Client VM (1.6.0-b105 mixed mode, sharing)
# Problematic frame:
# V [libjvm.so+0x217416]
# An error report file with more information is saved as
hs_err_pid12492.log
# If you would like to submit a bug report, please visit:
# http://java.sun.com/webapps/bugreport/crash.jsp
I was wondering if someone else had this problem and if there is a way to
solve it. I sent already the report to Sun Systems. The complete log error
is given below:
# SIGSEGV (0xb) at pc=0x06217416, pid=7797, tid=3076548288
--------------- T H R E A D ---------------
Current thread (0x0809f400): JavaThread "main" [_thread_in_vm, id=7797]
siginfo:si_signo=11, si_errno=0, si_code=1, si_addr=0x00000000
Registers:
EAX=0x00000000, EBX=0xbfd7ddf8, ECX=0x00000000, EDX=0x0809f400
ESP=0xbfd7ddf8, EBP=0xbfd7de70, ESI=0x00000000, EDI=0x0809f400
EIP=0x06217416, CR2=0x00000000, EFLAGS=0x00210246
Top of Stack: (sp=0xbfd7ddf8)
0xbfd7ddf8: 01910e1c 03e00003 0000010c 0017aea2
0xbfd7de08: 00000001 00000001 082680d8 0809f400
0xbfd7de18: 0000000a 0809f400 bfd7de70 06211a8a
0xbfd7de28: 0809f400 00000000 00000000 00000000
0xbfd7de38: 0809f400 03e00003 bfd7de70 062326fb
0xbfd7de48: 0809f400 00000001 082680d8 08246f60
0xbfd7de58: 01910e1c 03e00003 000000fa b4b8a0f4
0xbfd7de68: 00000000 00000000 bfd7deb0 b4b89416
Instructions: (pc=0x06217416)
0x06217406: 02 00 00 8b 45 10 8d 5d 88 c7 45 a8 0a 00 00 00
0x06217416: 8b 08 8d 75 a8 8b 41 08 8b 51 0c 83 c2 1c 66 8b
Stack: [0xbfd2f000,0xbfd7f000), sp=0xbfd7ddf8, free space=315k
Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native
code)
C [libswt-gtk-3346.so+0x2416] callback+0x1e4
C 0xb4b31195
C [libgdk-x11-2.0.so.0+0x42961]
C [libgdk-x11-2.0.so.0+0x440cc]
C [libgdk-x11-2.0.so.0+0x45cfb] _gdk_events_queue+0xdb
C [libgdk-x11-2.0.so.0+0x460ff]
C [libglib-2.0.so.0+0x2ddf2] g_main_context_dispatch+0x182
C [libglib-2.0.so.0+0x30dcf]
C [libglib-2.0.so.0+0x31335] g_main_context_iteration+0x65
C [eclipse_1020.so+0x54fe] dispatchMessages+0x1f
C [eclipse_1020.so+0x557b] takeDownSplash+0x5a
C [eclipse_1020.so+0x5a1e]
Java_org_eclipse_equinox_launcher_JNIBridge__1takedown_1spla sh+0x20
j org.eclipse.equinox.launcher.JNIBridge._takedown_splash()V+0
j org.eclipse.equinox.launcher.JNIBridge.takeDownSplash()Z+1
j org.eclipse.equinox.launcher.Main.takeDownSplash()V+20
j org.eclipse.equinox.launcher.Main$SplashHandler.run()V+4
j
org.eclipse.core.runtime.adaptor.EclipseStarter.run([Ljava/l ang/String;Ljava/lang/Runnable;)Ljava/lang/Object;+317
v ~StubRoutines::call_stub
V [libjvm.so+0x20967d]
V [libjvm.so+0x3057d8]
V [libjvm.so+0x209510]
V [libjvm.so+0x32c18f]
V [libjvm.so+0x32eb8c]
V [libjvm.so+0x2755f8]
C [libjava.so+0x15224]
Java_sun_reflect_NativeMethodAccessorImpl_invoke0+0x34
j
sun.reflect.NativeMethodAccessorImpl.invoke0(Ljava/lang/refl ect/Method;Ljava/lang/Object;[Ljava/lang/Object;)Ljava/lang/ Object;+0
j
sun.reflect.NativeMethodAccessorImpl.invoke(Ljava/lang/Objec t;[Ljava/lang/Object;)Ljava/lang/Object;+87
j
sun.reflect.DelegatingMethodAccessorImpl.invoke(Ljava/lang/O bject;[Ljava/lang/Object;)Ljava/lang/Object;+6
j
java.lang.reflect.Method.invoke(Ljava/lang/Object;[Ljava/lan g/Object;)Ljava/lang/Object;+161
j
org.eclipse.equinox.launcher.Main.invokeFramework([Ljava/lan g/String;[Ljava/net/URL;)V+210
j org.eclipse.equinox.launcher.Main.basicRun([Ljava/lang/Strin g;)V+114
j org.eclipse.equinox.launcher.Main.run([Ljava/lang/String;)I+ 4
V [libjvm.so+0x232b87]
V [libjvm.so+0x21717d]
C [eclipse_1020.so+0x6133] startJavaJNI+0x1c4
C [eclipse_1020.so+0x71c9] startJavaVM+0x21
C [eclipse_1020.so+0x32a2] run+0x40a
C [eclipse+0x12e7]
C [libc.so.6+0x15ebc] __libc_start_main+0xdc
Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
j
j
j
j
j
j
--------------- P R O C E S S ---------------
Java Threads: ( => current thread )
0x08323400 JavaThread "Start Level Event Dispatcher" daemon
[_thread_blocked, id=7811]
0x08357400 JavaThread "Framework Event Dispatcher" daemon
[_thread_blocked, id=7810]
0x08328000 JavaThread "State Data Manager" daemon [_thread_blocked,
id=7809]
0x080d3400 JavaThread "Low Memory Detector" daemon [_thread_blocked,
id=7803]
0x080d1c00 JavaThread "CompilerThread0" daemon [_thread_blocked, id=7802]
0x080d0400 JavaThread "Signal Dispatcher" daemon [_thread_blocked,
id=7801]
0x080c8800 JavaThread "Finalizer" daemon [_thread_blocked, id=7800]
0x080c7800 JavaThread "Reference Handler" daemon [_thread_blocked,
id=7799]
=>0x0809f400 JavaThread "main" [_thread_in_vm, id=7797]
Other Threads:
0x080be000 VMThread [id=7798]
0x080d4c00 WatcherThread [id=7804]
VM state:not at safepoint (normal execution)
VM Mutex/Monitor currently owned by a thread: None
Heap
def new generation total 2880K, used 2297K [0x80000000, 0x80310000,
0x813b0000)
eden space 2624K, 83% used [0x80000000, 0x802224d0, 0x80290000)
from space 256K, 43% used [0x802d0000, 0x802ebf58, 0x80310000)
to space 256K, 0% used [0x80290000, 0x80290000, 0x802d0000)
tenured generation total 37824K, used 2546K [0x813b0000, 0x838a0000,
0x90000000)
the space 37824K, 6% used [0x813b0000, 0x8162cbb0, 0x8162cc00,
0x838a0000)
compacting perm gen total 12288K, used 7011K [0x90000000, 0x90c00000,
0x94000000)
the space 12288K, 57% used [0x90000000, 0x906d8d00, 0x906d8e00,
0x90c00000)
ro space 8192K, 73% used [0x94000000, 0x945de548, 0x945de600,
0x94800000)
rw space 12288K, 57% used [0x94800000, 0x94ef16c0, 0x94ef1800,
0x95400000)
Dynamic libraries:
06000000-06412000 r-xp 00000000 08:07 1147069
/usr/lib/jvm/java-6-sun-1.6.0.00/jre/lib/i386/client/libjvm. so
06412000-0642b000 rw-p 00411000 08:07 1147069
0642b000-0684a000 rw-p 0642b000 00:00 0
08048000-0804b000 r-xp 00000000 08:06 621049
/home/aaragon/lib/eclipse/eclipse
0804b000-0804c000 rw-p 00002000 08:06 621049
0804c000-084fd000 rw-p 0804c000 00:00 0 [heap]
80000000-80310000 rwxp 80000000 00:00 0
80310000-813b0000 rwxp 80310000 00:00 0
813b0000-838a0000 rwxp 813b0000 00:00 0
838a0000-90000000 rwxp 838a0000 00:00 0
90000000-90c00000 rwxp 90000000 00:00 0
90c00000-94000000 rwxp 90c00000 00:00 0
94000000-945df000 r--s 00001000 08:07 1149130
/usr/lib/jvm/java-6-sun-1.6.0.00/jre/lib/i386/client/classes .jsa
945df000-94800000 rwxp 945df000 00:00 0
94800000-94ef2000 rw-p 005e0000 08:07 1149130
94ef2000-95400000 rwxp 94ef2000 00:00 0
95400000-954d9000 rw-p 00cd2000 08:07 1149130
954d9000-95800000 rwxp 954d9000 00:00 0
95800000-95804000 r-xs 00dab000 08:07 1149130
95804000-95c00000 rwxp 95804000 00:00 0
b4aee000-b4af1000 r--s 0001b000 08:06 620559
/home/aaragon/lib/eclipse/plugins/org.eclipse.core.resources .compatibility_3.2.100.v20070502.jar
b4af1000-b4afb000 r--s 0009c000 08:06 620374
/home/aaragon/lib/eclipse/plugins/org.eclipse.core.resources _3.3.0.v20070604.jar
b4afb000-b4b18000 r--s 0018c000 08:06 620972
/home/aaragon/lib/eclipse/plugins/org.eclipse.ui.ide_3.3.1.M 20070910-0800b.jar
b4b18000-b4b1c000 r-xp 00000000 08:07 673061 /usr/lib/libXtst.so.6.1.0
b4b1c000-b4b1d000 rw-p 00003000 08:07 673061 /usr/lib/libXtst.so.6.1.0
b4b1d000-b4b21000 r-xp 00000000 08:07 673423
/usr/lib/libgthread-2.0.so.0.1200.11
b4b21000-b4b22000 rw-p 00003000 08:07 673423
b4b31000-b4b33000 rwxp b4b31000 00:00 0
b4b33000-b4b84000 r-xp 00000000 08:06 621082
/home/aaragon/lib/eclipse/configuration/org.eclipse.osgi/bun dles/114/1/.cp/libswt-pi-gtk-3346.so
b4b84000-b4b86000 rw-p 00050000 08:06 621082
b4b86000-b4b87000 rw-p b4b86000 00:00 0
b4b87000-b4b8a000 r-xp 00000000 08:06 621081
/home/aaragon/lib/eclipse/configuration/org.eclipse.osgi/bun dles/114/1/.cp/libswt-gtk-3346.so
b4b8a000-b4b8b000 rw-p 00003000 08:06 621081
b4b8b000-b4b8f000 r--s 00016000 08:06 620399
/home/aaragon/lib/eclipse/plugins/org.eclipse.core.commands_ 3.3.0.I20070605-0010.jar
b4b8f000-b4b93000 r--s 0001f000 08:06 620978
/home/aaragon/lib/eclipse/plugins/org.eclipse.ui_3.3.1.M2007 0910-0800b.jar
b4b93000-b4ba5000 r--s 001c2000 08:06 620482
/home/aaragon/lib/eclipse/plugins/org.eclipse.swt.gtk.linux. x86_3.3.1.v3346i.jar
b4ba5000-b4ba6000 r--s 00003000 08:06 620474
/home/aaragon/lib/eclipse/plugins/org.eclipse.swt_3.3.1.v334 6j.jar
b4ba6000-b4bb9000 r--s 000dc000 08:06 620939
/home/aaragon/lib/eclipse/plugins/org.eclipse.jface_3.3.1.M2 0070910-0800b.jar
b4bb9000-b4bba000 r--s 00001000 08:06 620554
/home/aaragon/lib/eclipse/plugins/org.eclipse.ui.workbench.c ompatibility_3.2.0.I20070319-0010/compatibility.jar
b4bba000-b4bfb000 r--s 00353000 08:06 620996
/home/aaragon/lib/eclipse/plugins/org.eclipse.ui.workbench_3 .3.1.M20070921-1200.jar
b4bfb000-b4bfd000 r--s 0000a000 08:06 620941
/home/aaragon/lib/eclipse/plugins/org.eclipse.ui.ide.applica tion_1.0.0.I20070530-0100.jar
b4bfd000-b4c00000 r--s 00014000 08:06 620985
/home/aaragon/lib/eclipse/plugins/org.eclipse.core.runtime.c ompatibility_3.1.200.v20070502.jar
b4c00000-b4c02000 r--s 00011000 08:06 620933
/home/aaragon/lib/eclipse/plugins/org.eclipse.equinox.app_1. 0.1.R33x_v20070828.jar
b4c02000-b4c04000 r--s 00012000 08:06 620384
/home/aaragon/lib/eclipse/plugins/org.eclipse.core.jobs_3.3. 1.R33x_v20070709.jar
b4c04000-b4c07000 r--s 00017000 08:06 620967
/home/aaragon/lib/eclipse/plugins/org.eclipse.equinox.prefer ences_3.2.100.v20070522.jar
b4c07000-b4c09000 r--s 00004000 08:06 620969
/home/aaragon/lib/eclipse/plugins/org.eclipse.core.runtime.c ompatibility.auth_3.2.100.v20070502.jar
b4c09000-b4c0d000 r--s 00024000 08:06 620557
/home/aaragon/lib/eclipse/plugins/org.eclipse.equinox.regist ry_3.3.1.R33x_v20070802.jar
b4c0d000-b4c0f000 r--s 00010000 08:06 620385
/home/aaragon/lib/eclipse/plugins/org.eclipse.core.runtime_3 .3.100.v20070530.jar
b4c0f000-b4c11000 r--s 00016000 08:06 620498
/home/aaragon/lib/eclipse/plugins/org.eclipse.update.configu rator_3.2.101.R33x_v20070810.jar
b4c11000-b4c13000 r--s 00015000 08:06 620971
/home/aaragon/lib/eclipse/plugins/org.eclipse.equinox.common _3.3.0.v20070426.jar
b4c13000-b4c16000 ---p b4c13000 00:00 0
b4c16000-b4c64000 rwxp b4c16000 00:00 0
b4c64000-b4c67000 ---p b4c64000 00:00 0
b4c67000-b4cb5000 rwxp b4c67000 00:00 0
b4cb5000-b4cb8000 ---p b4cb5000 00:00 0
b4cb8000-b4d06000 rwxp b4cb8000 00:00 0
b4d06000-b4d0d000 r-xp 00000000 08:07 1147081
/usr/lib/jvm/java-6-sun-1.6.0.00/jre/lib/i386/libnio.so
b4d0d000-b4d0e000 rw-p 00006000 08:07 1147081
b4d0e000-b4d21000 r-xp 00000000 08:07 1147080
/usr/lib/jvm/java-6-sun-1.6.0.00/jre/lib/i386/libnet.so
b4d21000-b4d22000 rw-p 00013000 08:07 1147080
b4d22000-b4d30000 r--s 000d5000 08:06 620496
/home/aaragon/lib/eclipse/plugins/org.eclipse.osgi_3.3.1.R33 x_v20070828.jar
b4d30000-b4d37000 r--s 00106000 08:07 1149025
/usr/lib/jvm/java-6-sun-1.6.0.00/jre/lib/resources.jar
b4d37000-b4d67000 rw-p b4d37000 00:00 0
b4d67000-b4ee1000 r--s 02c68000 08:07 1149050
/usr/lib/jvm/java-6-sun-1.6.0.00/jre/lib/rt.jar
b4ee1000-b4ee2000 ---p b4ee1000 00:00 0
b4ee2000-b4f62000 rwxp b4ee2000 00:00 0
b4f62000-b4f65000 ---p b4f62000 00:00 0
b4f65000-b4fb3000 rwxp b4f65000 00:00 0
b4fb3000-b4fb6000 ---p b4fb3000 00:00 0
b4fb6000-b5034000 rwxp b4fb6000 00:00 0
b5034000-b5037000 ---p b5034000 00:00 0
b5037000-b5085000 rwxp b5037000 00:00 0
b5085000-b5088000 ---p b5085000 00:00 0
b5088000-b50d6000 rwxp b5088000 00:00 0
b50d6000-b50d9000 ---p b50d6000 00:00 0
b50d9000-b5127000 rwxp b50d9000 00:00 0
b5127000-b5128000 ---p b5127000 00:00 0
b5128000-b51b6000 rwxp b5128000 00:00 0
b51b6000-b51d0000 rwxp b51b6000 00:00 0
b51d0000-b51e3000 rwxp b51d0000 00:00 0
b51e3000-b5247000 rwxp b51e3000 00:00 0
b5247000-b5249000 rwxp b5247000 00:00 0
b5249000-b5250000 rwxp b5249000 00:00 0
b5250000-b5264000 rwxp b5250000 00:00 0
b5264000-b52c7000 rwxp b5264000 00:00 0
b52c7000-b52cd000 rwxp b52c7000 00:00 0
b52cd000-b52e7000 rwxp b52cd000 00:00 0
b52e7000-b52f7000 rwxp b52e7000 00:00 0
b52f7000-b5372000 rwxp b52f7000 00:00 0
b5372000-b547a000 rwxp b5372000 00:00 0
b547a000-b7372000 rwxp b547a000 00:00 0
b7372000-b7381000 r-xp 00000000 08:07 1147076
/usr/lib/jvm/java-6-sun-1.6.0.00/jre/lib/i386/libzip.so
b7381000-b7383000 rw-p 0000e000 08:07 1147076
b7383000-b73a6000 r-xp 00000000 08:07 1147075
/usr/lib/jvm/java-6-sun-1.6.0.00/jre/lib/i386/libjava.so
b73a6000-b73a8000 rw-p 00023000 08:07 1147075
b73a8000-b73b3000 r-xp 00000000 08:07 1147074
/usr/lib/jvm/java-6-sun-1.6.0.00/jre/lib/i386/libverify.so
b73b3000-b73b4000 rw-p 0000b000 08:07 1147074
b73b4000-b73bb000 r-xp 00000000 08:07 1082529
/lib/tls/i686/cmov/librt-2.5.so
b73bb000-b73bd000 rw-p 00006000 08:07 1082529
b73be000-b73c0000 r--s 00009000 08:06 620478
/home/aaragon/lib/eclipse/plugins/org.eclipse.equinox.launch er_1.0.1.R33x_v20070828.jar
b73c0000-b73c5000 rwxp b73c0000 00:00 0
b73c5000-b73cb000 r-xp 00000000 08:07 1147050
/usr/lib/jvm/java-6-sun-1.6.0.00/jre/lib/i386/native_threads /libhpi.so
b73cb000-b73cc000 rw-p 00006000 08:07 1147050
b73cc000-b73cd000 rwxp b73cc000 00:00 0
b73cd000-b73ce000 r--p b73cd000 00:00 0
b73ce000-b742e000 rw-s 00000000 00:08 2752536 /SYSV00000000 (deleted)
b742e000-b7491000 rw-p b742e000 00:00 0
b7491000-b74a3000 r-xp 00000000 08:07 721635
/usr/lib/gtk-2.0/2.10.0/engines/libubuntulooks.so
b74a3000-b74a4000 rw-p 00011000 08:07 721635
b74a4000-b74ad000 r-xp 00000000 08:07 1082516
/lib/tls/i686/cmov/libnss_files-2.5.so
b74ad000-b74af000 rw-p 00008000 08:07 1082516
b74af000-b74b7000 r-xp 00000000 08:07 1082520
/lib/tls/i686/cmov/libnss_nis-2.5.so
b74b7000-b74b9000 rw-p 00007000 08:07 1082520
b74b9000-b74cc000 r-xp 00000000 08:07 1082510
/lib/tls/i686/cmov/libnsl-2.5.so
b74cc000-b74ce000 rw-p 00012000 08:07 1082510
b74ce000-b74d0000 rw-p b74ce000 00:00 0
b74d0000-b74d7000 r-xp 00000000 08:07 1082512
/lib/tls/i686/cmov/libnss_compat-2.5.so
b74d7000-b74d9000 rw-p 00006000 08:07 1082512
b74da000-b74e2000 rw-s 00000000 08:07 1328720
/tmp/hsperfdata_aaragon/7797
b74e2000-b74e5000 r-xp 00000000 08:07 721650
/usr/lib/gtk-2.0/2.10.0/loaders/libpixbufloader-bmp.so
b74e5000-b74e6000 rw-p 00002000 08:07 721650
b74e6000-b74e7000 r--s 00002000 08:06 620961
/home/aaragon/lib/eclipse/plugins/org.eclipse.core.runtime.c ompatibility.registry_3.2.100.v20070316/runtime_registry_com patibility.jar
b74e7000-b74e8000 r-xp 00000000 08:07 426166
/usr/lib/gconv/ISO8859-1.so
b74e8000-b74ea000 rw-p 00000000 08:07 426166
b74ea000-b74f3000 r-xp 00000000 08:06 620989
/home/aaragon/lib/eclipse/plugins/org.eclipse.equinox.launch er.gtk.linux.x86_1.0.1.R33x_v20070828/eclipse_1020.so
b74f3000-b74f4000 rw-p 00008000 08:06 620989
b74f4000-b752f000 r--p 00000000 08:07 737942
/usr/lib/locale/en_US.utf8/LC_CTYPE
b752f000-b7606000 r--p 00000000 08:07 737941
/usr/lib/locale/en_US.utf8/LC_COLLATE
b7606000-b7608000 rw-p b7606000 00:00 0
b7608000-b7626000 r-xp 00000000 08:07 673214 /usr/lib/libexpat.so.1.0.0
b7626000-b7628000 rw-p 0001d000 08:07 673214 /usr/lib/libexpat.so.1.0.0
b7628000-b7629000 rw-p b7628000 00:00 0
b7629000-b764b000 r-xp 00000000 08:07 674863
/usr/lib/libpng12.so.0.15.0
b764b000-b764c000 rw-p 00021000 08:07 674863
b764c000-b7650000 r-xp 00000000 08:07 673029 /usr/lib/libXdmcp.so.6.0.0
b7650000-b7651000 rw-p 00003000 08:07 673029 /usr/lib/libXdmcp.so.6.0.0
b7651000-b7653000 r-xp 00000000 08:07 673018 /usr/lib/libXau.so.6.0.0
b7653000-b7654000 rw-p 00001000 08:07 673018 /usr/lib/libXau.so.6.0.0
b7654000-b7667000 r-xp 00000000 08:07 673773 /usr/lib/libz.so.1.2.3
b7667000-b7668000 rw-p 00012000 08:07 673773 /usr/lib/libz.so.1.2.3
b7668000-b76d0000 r-xp 00000000 08:07 674724
/usr/lib/libfreetype.so.6.3.10
b76d0000-b76d3000 rw-p 00068000 08:07 674724
b76d3000-b76d4000 rw-p b76d3000 00:00 0
b76d4000-b76fe000 r-xp 00000000 08:07 673606
/usr/lib/libpangoft2-1.0.so.0.1600.2
b76fe000-b76ff000 rw-p 0002a000 08:07 673606
b76ff000-b7707000 r-xp 00000000 08:07 673025
/usr/lib/libXcursor.so.1.0.2
b7707000-b7708000 rw-p 00007000 08:07 673025
b7708000-b770d000 r-xp 00000000 08:07 673053
/usr/lib/libXrandr.so.2.1.0
b770d000-b770e000 rw-p 00005000 08:07 673053
b770e000-b7715000 r-xp 00000000 08:07 673041 /usr/lib/libXi.so.6.0.0
b7715000-b7716000 rw-p 00006000 08:07 673041 /usr/lib/libXi.so.6.0.0
b7716000-b7718000 r-xp 00000000 08:07 673043
/usr/lib/libXinerama.so.1.0.0
b7718000-b7719000 rw-p 00001000 08:07 673043
b7719000-b771a000 rw-p b7719000 00:00 0
b771a000-b7721000 r-xp 00000000 08:07 673055
/usr/lib/libXrender.so.1.3.0
b7721000-b7722000 rw-p 00006000 08:07 673055
b7722000-b772f000 r-xp 00000000 08:07 673033 /usr/lib/libXext.so.6.4.0
b772f000-b7730000 rw-p 0000d000 08:07 673033 /usr/lib/libXext.so.6.4.0
b7730000-b7753000 r-xp 00000000 08:07 673220
/usr/lib/libfontconfig.so.1.2.0
b7753000-b775b000 rw-p 00023000 08:07 673220
b775b000-b7780000 r-xp 00000000 08:07 1082507
/lib/tls/i686/cmov/libm-2.5.so
b7780000-b7782000 rw-p 00024000 08:07 1082507
b7782000-b77f0000 r-xp 00000000 08:07 673122
/usr/lib/libcairo.so.2.11.1
b77f0000-b77f2000 rw-p 0006d000 08:07 673122
b77f2000-b77f3000 rw-p b77f2000 00:00 0
b77f3000-b7887000 r-xp 00000000 08:07 673315
/usr/lib/libglib-2.0.so.0.1200.11
b7887000-b7888000 rw-p 00093000 08:07 673315
b7888000-b788a000 r-xp 00000000 08:07 673325
/usr/lib/libgmodule-2.0.so.0.1200.11
b788a000-b788b000 rw-p 00002000 08:07 673325
b788b000-b78a4000 r-xp 00000000 08:07 673089
/usr/lib/libatk-1.0.so.0.1809.1
b78a4000-b78a6000 rw-p 00018000 08:07 673089
b78a6000-b78aa000 r-xp 00000000 08:07 673035
/usr/lib/libXfixes.so.3.1.0
b78aa000-b78ab000 rw-p 00003000 08:07 673035
b78ab000-b7998000 r-xp 00000000 08:07 673012 /usr/lib/libX11.so.6.2.0
b7998000-b799c000 rw-p 000ed000 08:07 673012 /usr/lib/libX11.so.6.2.0
b799c000-b79d8000 r-xp 00000000 08:07 673602
/usr/lib/libpango-1.0.so.0.1600.2
b79d8000-b79da000 rw-p 0003b000 08:07 673602
b79da000-b79db000 rw-p b79da000 00:00 0
b79db000-b79e2000 r-xp 00000000 08:07 673604
/usr/lib/libpangocairo-1.0.so.0.1600.2
b79e2000-b79e3000 rw-p 00007000 08:07 673604
b79e3000-b7b1e000 r-xp 00000000 08:07 1082499
/lib/tls/i686/cmov/libc-2.5.so
b7b1e000-b7b1f000 r--p 0013b000 08:07 1082499
b7b1f000-b7b21000 rw-p 0013c000 08:07 1082499
b7b21000-b7b24000 rw-p b7b21000 00:00 0
b7b24000-b7b26000 r-xp 00000000 08:07 1082505
/lib/tls/i686/cmov/libdl-2.5.so
b7b26000-b7b28000 rw-p 00001000 08:07 1082505
b7b28000-b7b3b000 r-xp 00000000 08:07 1082525
/lib/tls/i686/cmov/libpthread-2.5.so
b7b3b000-b7b3d000 rw-p 00013000 08:07 1082525
b7b3d000-b7b3f000 rw-p b7b3d000 00:00 0
b7b3f000-b7bc2000 r-xp 00000000 08:07 673277
/usr/lib/libgdk-x11-2.0.so.0.1000.11
b7bc2000-b7bc5000 rw-p 00083000 08:07 673277
b7bc5000-b7bfe000 r-xp 00000000 08:07 673369
/usr/lib/libgobject-2.0.so.0.1200.11
b7bfe000-b7bff000 rw-p 00039000 08:07 673369
b7bff000-b7c00000 rw-p b7bff000 00:00 0
b7c00000-b7c16000 r-xp 00000000 08:07 673279
/usr/lib/libgdk_pixbuf-2.0.so.0.1000.11
b7c16000-b7c17000 rw-p 00015000 08:07 673279
b7c17000-b7f68000 r-xp 00000000 08:07 673426
/usr/lib/libgtk-x11-2.0.so.0.1000.11
b7f68000-b7f6e000 rw-p 00351000 08:07 673426
b7f6e000-b7f6f000 rw-p b7f6e000 00:00 0
b7f6f000-b7f70000 r--p 00000000 08:07 737947
/usr/lib/locale/en_US.utf8/LC_NUMERIC
b7f70000-b7f71000 r--p 00000000 08:07 737950
/usr/lib/locale/en_US.utf8/LC_TIME
b7f71000-b7f72000 r--p 00000000 08:07 737945
/usr/lib/locale/en_US.utf8/LC_MONETARY
b7f72000-b7f73000 r--p 00000000 08:07 753674
/usr/lib/locale/en_US.utf8/LC_MESSAGES/SYS_LC_MESSAGES
b7f73000-b7f74000 r--p 00000000 08:07 737948
/usr/lib/locale/en_US.utf8/LC_PAPER
b7f74000-b7f75000 r--p 00000000 08:07 737946
/usr/lib/locale/en_US.utf8/LC_NAME
b7f75000-b7f76000 r--p 00000000 08:07 737940
/usr/lib/locale/en_US.utf8/LC_ADDRESS
b7f76000-b7f77000 r--p 00000000 08:07 737949
/usr/lib/locale/en_US.utf8/LC_TELEPHONE
b7f77000-b7f78000 r--p 00000000 08:07 737944
/usr/lib/locale/en_US.utf8/LC_MEASUREMENT
b7f78000-b7f7f000 r--s 00000000 08:07 426219
/usr/lib/gconv/gconv-modules.cache
b7f7f000-b7f80000 r--p 00000000 08:07 737943
/usr/lib/locale/en_US.utf8/LC_IDENTIFICATION
b7f80000-b7f82000 rw-p b7f80000 00:00 0
b7f82000-b7f9b000 r-xp 00000000 08:07 1048597 /lib/ld-2.5.so
b7f9b000-b7f9d000 rw-p 00019000 08:07 1048597 /lib/ld-2.5.so
bfd2f000-bfd32000 ---p bfd2f000 00:00 0
bfd32000-bfd7f000 rwxp bfd32000 00:00 0 [stack]
bfd7f000-bfd82000 rw-p bfd7f000 00:00 0
ffffe000-fffff000 r-xp 00000000 00:00 0 [vdso]
VM Arguments:
jvm_args: -Dosgi.requiredJavaVersion=1.5 -Xms40m -Xmx256m
java_command: <unknown>
Launcher Type: generic
Environment Variables:
PATH=/home/aaragon/mpich-1.2.7/bin:/home/aaragon/bin:/usr/lo cal/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/g ames
USERNAME=aaragon
LD_LIBRARY_PATH=/usr/lib/jvm/java-6-sun-1.6.0.00/jre/lib/i38 6/client::/usr/lib/jvm/java-6-sun-1.6.0.00/jre/lib/i386::/us r/lib/mozilla-thunderbird:/usr/lib/mozilla-thunderbird
SHELL=/bin/bash
DISPLAY=:0.0
Signal Handlers:
SIGSEGV: [libjvm.so+0x3aea90], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGBUS: [libjvm.so+0x3aea90], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGFPE: [libjvm.so+0x304e70], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGPIPE: [libjvm.so+0x304e70], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGILL: [libjvm.so+0x304e70], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGUSR1: SIG_DFL, sa_mask[0]=0x00000000, sa_flags=0x00000000
SIGUSR2: [libjvm.so+0x306e80], sa_mask[0]=0x00000000, sa_flags=0x10000004
SIGHUP: [libjvm.so+0x3068a0], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGINT: [libjvm.so+0x3068a0], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGQUIT: [libjvm.so+0x3068a0], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGTERM: [libjvm.so+0x3068a0], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
--------------- S Y S T E M ---------------
OS:4.0
uname:Linux 2.6.20-16-generic #2 SMP Sun Sep 23 19:50:39 UTC 2007 i686
libc:glibc 2.5 NPTL 2.5
rlimit: STACK 8192k, CORE 0k, NPROC infinity, NOFILE 1024, AS infinity
load average:0.22 0.27 0.32
CPU:total 1 family 6, cmov, cx8, fxsr, mmx, sse, sse2
Memory: 4k page, physical 1546676k(684728k free), swap 2996080k(2996080k
free)
vm_info: Java HotSpot(TM) Client VM (1.6.0-b105) for linux-x86, built on
Nov 29 2006 01:24:38 by "java_re" with gcc 3.2.1-7a (J2SE release)
Re: Eclipse Europa just stopped working! [message #203208 is a reply to message #203074] |
Tue, 23 October 2007 05:47  |
> following message:
> hs_err_pid12492.log
> to solve it. I sent already the report to Sun Systems. The complete log
> error is given below:
I suggest to search Eclipse bugzilla for similar crashes and report it
there.
Anton Leherbauer
Wind River CDT Team, Austria
Current Time: Sun Aug 31 12:07:00 EDT 2025
Powered by FUDForum. Page generated in 0.09292 seconds
