Home » Newcomers » Newcomers » how to get another Plugin's static share object that the plugin class provides
how to get another Plugin's static share object that the plugin class provides [message #202932] Tue, 03 April 2007 02:12 Go to next message
Originally posted by: ludinghong1981.163.com
hello everyone !
had built two plugins,A and B. A is loaded as the eclipse startup,and
create a TCP/IP connection.Then In B,I want to use this connection for
communication. how can I do to get the object that generated in plugin A.
I think I should first to get the A's plugin object that defined in A's
plugin class(actually I guess that when eclipse loads A,the static plugin
object was created),but I do not konw how?
anyone can help me ?
Re: how to get another Plugin's static share object that the plugin class provides [message #203114 is a reply to message #202932] Tue, 03 April 2007 23:56 Go to previous messageGo to next message
Originally posted by: irbull.cs.uvic.ca
Check your MANIFEST.MF file, and see if you plug-in defines an
activator. If it does, you should be able to communicate using this.
For example, if A defines the activator APlugin, then you should be able
to say APlugin.getDefault() to get the default instance.
cheers,
ian
LU wrote:
> hello everyone !
> plugin object was created),but I do not konw how?
Re: how to get another Plugin's static share object that the plugin class provides [message #203203 is a reply to message #203114] Wed, 04 April 2007 02:04 Go to previous messageGo to next message
ok !thanks!
after geting the Aplugin object,then I can get any object that I have
defined in the Aplugin class.is that what you want to tell me?
thank you again!
Re: how to get another Plugin's static share object that the plugin class provides [message #203322 is a reply to message #203203] Wed, 04 April 2007 13:03 Go to previous messageGo to next message
Oh, sorry...
No, this is just like any other Java application, it all depends on how
you architect your system. If you have some sort of Object in Plugin A
that you want to share with other plugins, I would probably instantiate
it when Plugin A is loaded, and then hold a reference to this in your
activator.
Then you can say APlugin.getDefault().getMySharedObject(). I sometimes
use the activator to hold a registry of things other plugins may need.
cheers,
ian
LU wrote:
> ok !thanks!
> thank you again!
Re: how to get another Plugin's static share object that the plugin class provides [message #203604 is a reply to message #203322] Thu, 05 April 2007 23:00 Go to previous message
thank you !
I got it!
Previous Topic:Setting Editor to read-only
Next Topic:Problem launching eclipse in Linux
Current Time: Tue Jul 22 12:57:03 EDT 2025
Powered by FUDForum. Page generated in 0.09108 seconds
