Home » Archived » BIRT » Strange Problem: The different "Show" between the HTML form and the PDF form?
Strange Problem: The different "Show" between the HTML form and the PDF form? [message #202797] Fri, 24 November 2006 07:04
Originally posted by: m.luo.cosmit.de
Hello All,
Here is a problem to get the same show between the HTML form and the PDF
form. That is, when I set a Image as the background in Master Page
(Background repeat: no repeat, Horizontal position: 0%, Vertical position:
0%), it shows the background only in the HTML form , and doesn't show in
PDF form.
However when I set it in: "Background repeat: repeat, Horizontal position:
0%, Vertical position: 0%", the background can show out in HTML form and PDF
form. But because of the size of the Image, the HTML form show 2 times, it
looks not good (in PDF form, it repeat 1 time and looks good).
Have someone met this problem? I want to show the same between the HTML and
PDF. Can someone help me?
Luo
Previous Topic:how to launch eclipse with my specific ".project "??
Next Topic:Data Set Error
Current Time: Sun Aug 31 17:36:31 EDT 2025
Powered by FUDForum. Page generated in 0.03210 seconds
