Home » Eclipse Projects » Nebula » PGroup (RectangleGroupStrategy) background color issue
PGroup (RectangleGroupStrategy) background color issue [message #19398] Mon, 04 December 2006 10:12 Go to next message
I'm having a trouble with a PGroup background color when using
RectangleGroupStrategy with SWT.SMOOTH style bit set on a group
(a bit odd style bit to imply rounded corners imo), if setting
background color to the PGroup to anything different from parent
background, the new background bleeds through the border, effectively
defeating the whole idea of having the border arount the group content...
Roland Tepp
Re: PGroup (RectangleGroupStrategy) background color issue [message #19490 is a reply to message #19398] Mon, 04 December 2006 10:53 Go to previous messageGo to next message
Hi Roland,
I think I know what you mean but I'm not exactly sure. Can you attach a
picture?
-Chris
SWT.SMOOTH may not be the best name but I have to make do with what I
got (i.e. the exising SWT constants).
Roland Tepp wrote:
> Hello,
Re: PGroup (RectangleGroupStrategy) background color issue [message #19535 is a reply to message #19490] Mon, 04 December 2006 11:29 Go to previous messageGo to next message
--------------070404050109070606020007
Hi Chris,
Attached to this message are the modified PGroup snippet code along with
the screenshot this code produces, illustrating my problem.
As You can see from the screenshot, the background of PGroup is bleeding
through the border here at the corners of the PGroup, where they should
be white, they are red instead.
It gets actually worse if I have an image set with the SWT.TOP style bit
in image positioning flag, where the entire top area of the PGroup gets
painted red...
Chris Gross kirjutas mulle midagi seesugust:
> Hi Roland,
> picture?
> -Chris
> Roland Tepp wrote:
>> Hello,
Roland Tepp
name="PGroupSnippet1.java"
Content-Disposition: inline;
filename="PGroupSnippet1.java"
* Copyright (c) 2006 IBM Corporation and others.
* All rights reserved. This program and the accompanying materials
* are made available under the terms of the Eclipse Public License v1.0
* which accompanies this distribution, and is available at
* http://www.eclipse.org/legal/epl-v10.html
* Contributors:
* IBM Corporation - initial API and implementation
package org.eclipse.swt.nebula.snippets.pgroup;
import org.eclipse.swt.SWT;
import org.eclipse.swt.layout.GridLayout;
import org.eclipse.swt.nebula.widgets.pgroup.PGroup;
import org.eclipse.swt.nebula.widgets.pgroup.RectangleGroupStrategy ;
import org.eclipse.swt.widgets.Button;
import org.eclipse.swt.widgets.Label;
import org.eclipse.swt.widgets.Scale;
import org.eclipse.swt.widgets.Shell;
* Creates a PGroup.
* For a list of all Nebula PGroup example snippets see
* http://www.eclipse.org/nebula/widgets/pgroup/snippets.php
public class PGroupSnippet1 {
public static void main (String [] args) {
Display display = new Display ();
Shell shell = new Shell (display);
shell.setBackground(display.getSystemColor(SWT.COLOR_WHITE)) ;
GridLayout gridLayout = new GridLayout();
gridLayout.marginWidth = 15;
gridLayout.marginHeight = 15;
shell.setLayout(gridLayout);
PGroup group = new PGroup(shell, SWT.SMOOTH);
group.setBackgroundMode(SWT.INHERIT_FORCE);
group.setText("Example");
RectangleGroupStrategy strategy = new RectangleGroupStrategy();
strategy.setBorderColor(display.getSystemColor(SWT.COLOR_BLA CK));
group.setStrategy(strategy);
// group.setToggleRenderer(new TwisteToggleRenderer());
group.setLayout(new GridLayout());
group.setBackground(display.getSystemColor(SWT.COLOR_RED));
Label label = new Label(group,SWT.NONE);
label.setText("Contents");
Button button = new Button(group,SWT.PUSH);
button.setText("Contents");
Scale scale = new Scale(group, SWT.HORIZONTAL);
shell.pack();
shell.open ();
while (!shell.isDisposed()) {
if (!display.readAndDispatch ()) display.sleep ();
display.dispose ();
Content-Type: image/png;
name="PGroup-bg-bleed.png"
filename="PGroup-bg-bleed.png"
iVBORw0KGgoAAAANSUhEUgAAANAAAACZCAIAAADRkSOHAAAABmJLR0QA/wD/ AP+gvaeTAAAA
CXBIWXMAAA7EAAAOxAGVKw4bAAANnklEQVR4nO3deXAUVR4H8G9nIYlKTGQT QsIRQkAgBGFh
USPrQhZdYcUySIkHGBDQEIN4FYKwoKBSrLglN0YuYRUlhUVRi+ARDHEFLxB0 IUY2yQwiRwho
JhBmpqf7vf2jp4dJAkmnZ+alE36f6kpN9/y63xvmy+vuOXokzjkIESWsuTtA ri4UOCIUBY4I
RYEjQlHgiFAUOCIUBY4IRYEjQlHgiFAUOCIUBY4IRYEjQrUxVCVJ/nPPbK8M SV9Iy/HGvXG1
5g1/BEQy9GkRPXBPb6toWr9Iq7ZkdLz3VigC99QHp0z2i7ReS8ckACEI3PT8 EwH0irRmy8Z2
Mh44Y8dwAGeq2f6QlqHXtiEYvReN/f1p9N5AWjE0wj353rFA2iAtQi/gp9pL lj+UVOepr1/j
qzTYiqERjqvM4OZCJbnDiiHX4fiZaUU1zdyT1kv6eDi/a7dvdsX4ZADLH0qa 9o7tSjUmGAsc
qx245PiVt7fzzZ05fHz+d3IgnWgc04ZhXrcnJHikOz/1/fOuzEoBkLupbGVW yorxybmbyurX
mGMwcLUP4LRn/+eTT3x2IZC2m8CbN5UOJUNHKrqHD/03gFUTbwTwxNtHtb+r Jt64MitFm/XV
mGZqhNMO+/il5enDe2cl4cz3thcPuLsM6j67fzgcZxcWYkpmbAd9Je1etI+d nxnbwSGfiQ7v
AADnNxUha2gUADjOLvzg7HGtwNeWttC/xZROq7V6370mHzupRbp9u/aE5qwv 0ZasntQ7Z32J
b9a/xjRDb21xldWatB1cUuLqSb1XT0q+L4bt+6R4ox0d+ifeF9Punv7hqDq7 MP/Mz5Vn5q0p
nrqmeOqask+rtHsZZ+AAol271hQvPOQGorKSHFPXFG+0A9Gx9yTrBVVnF2oF 0bGTB7b1tsgZ
j4l9aWhUxaGyqWuKpxZWe++t0z2aTE3SV2P8Z1dP6q1lroEa32Q8cOZGOACA /Xj2xw7fsn0f
lyY80OOv93UGqt/eclo7t0m6pefsARH+2+HaylXuE/o2K6pcnHmP0cD1NIOD sWO/uoGI+Jhw
/qv37q7do+IBDEh5c4B3m/Ex4Zw5jT9gciXSoC2+JzovOw1Adt7hvOy0Nx9L zc47XL/GHGOv
w9U9hvOON7WXt02I8d6tLU+6pdfsAREV3x2d97UzfUT/icnacq27DEz1ngow Bqb6jtLA/Ap8
DV1qkQPQtmnm4ZIG/HcC+m0EkJfTH0D26u+1v3k5/fOy07RZX41ppl4W8e7g uP/y2/6W1A9V
b6+oGjit28QH40+8eyoxJlJbmavhiVoWfSOctq7vVEC/zZk+wnHOVZaeHA3g h9JfOaK1hfZz
LiAyfmCH9H22fQE8bFKflLpBe0IfX3HQf7n/rK/GNFO7VC0T3bu9Na0bgIoD tkPdk++6AT98
XLaX4ZcDHW8a1HHOOP7Kv2w/TE++aVCftwa5Kn7zboej/gsc/NIu1Re4GzrO mdYRAMpty39k
6KWv9WPZY5WJrzycMHHaHyYCACoOFP99L412QSCVZfOUvMBrGtmCkXcapiz5 NpA2miau06vj
EuN/O/nyxhP0/oZI6QCO5SJpZcN/v7zcumufHmywFYO7VIGvfqn6YKaqdJkd kfYB6LwMqtrI
38CY2qWGVMWxFxbT0NZqWS9wpFUz+LIIBY4Eh/WO4UirRrtUIpTRT/xufPGO kPaDtFwT5hcY
L6bvpRKhKHBEKAocEYoCR4SiwBGhKHBEqIACJ/lNxo0E7KGsJ1ZmMnB2QAIK AQ5woBDYE8xe
kVbLZOB2A2uBYfrsMP32SH3A26PPrtOXzAAArAM+ApKBkbXr1xmot/sNqHZz /SbNzWTgtgIp
9RbOANIADtiADH1hiT4Kvg7YgcnACMAG7AJmADP1e7fqGWqgPkcfUwspcC2W 0be26utWb8lh
YLV+1wh9kMvV7x1xufrX/WbtjdWnARlAod/ISlockyNcGhDQFSZ0Nn084wZi tBjgwId+u2zS
4pgMXC4wxe9Z3wPsAdKAlQAAO/BRgwGyA/Crb5RWrx3VLQbWAmVN6i6xDJO7 1G6ADUj2W6IN
USP1l0gKr7zuTCADGAHs8qsHYGusPk0v1tYlLVFAx3D1v+Sy68qzvtvD/FZs av3ipvWRWA69
00CEosARoShwRCgKHBGKAkeEosARoUy+LMJTUxEXd7F3j+D2JlgkSNeU/A+V lVJxcXP3hdRi
9nW4uLj8WYu3Fuw/Wn5OZda66ExYmNS1U/Qjsx4fu2hGc/eF1GUycM7ePTfv /Lpfj+QFT45l
rGkfwAwpDoSF4d3tX23e+XVmv9SIoqLm7hGpxfw7Dcd+qVo6JyPh99dKFjsO 5AxTHsjIzDkY
1sViPSPmj+HAGecul/K7MLg8we1SoCLbwuVSGOdN/Og7EcFk4CRIADwqZxzX hlvrGE5hksd7
LUMKnOWY36UCUJnKGWeStQLHGVT6wRqrCihwisIY58Z/K1MMxqEodLkniwro sFpRVc65wph3
Knw+sk0b7/R84aXlDU/2taNGri03WGygnnOu0AXtrCqgwKkqZ/rP39jX3d3u Tr7D5Xa43A6X
ewffucfgb+6o4AAzWGygnjG6HrV1BRg4lXOuKExR7AUfYEnxwnSFKQpTFJb+ 8sJ0hSnl6zMj
I6IjI6IjZ+7RZket3zBTWxIxp5Apin1D7tTdn05Ni4zIXGf3qx+1obzxetu6 Udpd0aPW2/Sm
OecqjXBWFVDgnLLq8aiKyhT77u0FqUmdmKL6T0VzU3P67KipcNTsX3743tlF CuMoyDl6Z02F
o6Zix1MrXt9gUzs/tGRVxvBV+x0174+3zU0tme6oqXDUVBwevf3JDbaG64fu fiY3dZujpsJR
sy21xKa36/GoTpkCZ1EBnTS4XB5ZURQOyIxl9EyQWa3f6T1eeiRjxT9uYbKM +CGZQ5/cWTTx
RpaxIusWJstAYs+hjCkyk2XGGBSZycdLj2Dpquil+vrTy+UG6+O73YgnRkfz /MpX0+e+Ar11
JjGX1V4bJLrAzlJVpjJ2rlrG9Z26FS7bdeSB0Z397q72eFT85nBFarehVtdZ ot32v/HnN3at
H5/g28Iv7zRUj8E5pZU5+OKNuKixyF1b+tIfAQCx14crzf6b6eQKAj1LZYw7 3YrTfWvmAj5/
2Ly9bsXpVpxuZe+r8/bGdU3+/Jl3/qM43Yrt8+37Hv1LXw9TVebSany3PUz9 /Gi5W3H61Tvr
1Fy23rZp8Wa7033r1CPfvjDkSJnNuxZjdJZqXQGNcB4PU1Qmyx4A7e/ZlK88 MravPjxlbSmS
B6d9+NqMuxPSASB7ycHB8skyzuGRPTIAWfXejr3/oayuuX1X3zxv3+JL9cBt r+XPQYP1r6Us
GJw+DwBunrdvcaxHlgFAUSM8HhrhLMrQj7tNWLC7zlXML2ZPubWi63OTR/9p QKLtlONKKzaL
5IToLw6d/Oe6bQe6VrZdtry5u9P6TZhfsHHecIPFgR3DMa4ydtElN14qkMqY YrGP6BGfAE8a
OMBlj9VOCbmictBb95ZkNnCSFCZJ4LhwUfZ4lKB2KVAXLsrgCJMkSBQ5yzH7 8SRJ6hDX7suD
P7rkHlZ7Xs/8dvrgkdKO8VGSVNncfSF1mQxcZPFPk2dNyf9k/4b8XcxinxaR JKlLp5hH770t
bNG25u4LqcvsLrWycuyiGWMG9JeSLDa+ebtzTlq0FZU0wlmO2V1qcTGANvQV FdJE9DUTIhQF
jghFgSNCUeCIUBQ4IhQFjghFgSNCUeCIUBQ4IlRoA/f+5vyQbp8EkZgnyyoj XJMerfHiUFQ2
ewdC1FUxrBI4cpWgwBGxuAFZ8wu43+9M0kST/5Q1v8BIijQBfaehvvOOU/uP nnXJcp0PZcoe
T9X5i2OG9omKTrjCquSqEOTA7T969nRE+TfXfeZkTg5v6FSuHnf+3KVq4Okt p2cFtz3S0gQ5
cC5Z/ua6zy6o50+6TjJ4v43MOCu9UFqilCReSAluc6TFCXLgOMcU9dm+aV2r q6urquTz1Rch
8erqakTCcV31Hvm74DZHWhw6SyVCUeCIUBQ4IhQFjghFgSNCBfkstVHr1+YJ bpGYMG78OFWR
r23XPuhbFh24++/PFNwiMYEztW34NaHYsujAMcUpuEViRtvIEG1YdOCi2ycJ bpGY4HbXeGRn
2xBsWXTgrHZtL3JZESHbMp2lEqEocEQoChwRigJHhKLAEaGCfJYqezzPOieX FpaqDhW+T5lz
sAuMufkj0gvBbY60OEEOXNX5i12qBpYoJayacd/vXUkAx8BzGbJirZ8QIeIF OXBjhvY5veV0
4oUUWXb7L5ckSVbkl6Y/jLnPBbdF0rIEOXBR0QkNfU2G0nbVs8q1RVrQlRaa vQPN3tVA0Fkq
EYoCR8QK6aUe3tuc3+wXIqDJ4GT6yWrSpR5CO8I9+PDYkG6fBJGYJ4t2qUQo ChwRigJHhKLA
EaEocEQoChwRigJHhKLAEaEocEQsQ+9HaG9fNPd7LzRZcPIGwyJvbRFSl8ER jtMgR1O96VIk
DJN4nV9UuCz9+gwT5hcA2PjiHSH9P0Csr24SjKQIANC0wPk3Rq5mdQedIAeO kCChkwYiFAWO
CEWBI0JR4IhQFDgiFAWOCEWBI0JR4IhQFDgiFAWOCEWBI0JR4IhQFDgiFAWO CEWBI0L9H1hY
ThmuRNXnAAAAAElFTkSuQmCC
--------------070404050109070606020007--
Re: PGroup (RectangleGroupStrategy) background color issue [message #19580 is a reply to message #19535] Mon, 04 December 2006 16:13 Go to previous messageGo to next message
Hi Roland,
Hmm.. Let me investigate this. I had specifically designed the new
PGroup background drawing logic to ensure that the new SWT 'inherit
background' features worked. Perhaps I was a bit over-zealous.
-Chris
Roland Tepp wrote:
> Hi Chris,
> painted red...
>> Hi Roland,
>> a picture?
>> -Chris
>> Roland Tepp wrote:
>>> Hello,
>>> content...
> * Contributors:
> import org.eclipse.swt.widgets.Display;
> * Creates a PGroup.
> shell.pack();
> shell.open ();
> display.dispose ();
Re: PGroup (RectangleGroupStrategy) background color issue [message #19670 is a reply to message #19535] Tue, 05 December 2006 16:56 Go to previous messageGo to next message
Roland,
I've updated PGroup again. Please try the new drop and see if that
works for you. I had to modify the background drawing logic.
-Chris
Roland Tepp wrote:
> Hi Chris,
> painted red...
>> Hi Roland,
>> a picture?
>> -Chris
>> Roland Tepp wrote:
>>> Hello,
>>> content...
> * Contributors:
> * Creates a PGroup.
> shell.pack();
> shell.open ();
> display.dispose ();
Re: PGroup (RectangleGroupStrategy) background color issue [message #21257 is a reply to message #19670] Thu, 21 December 2006 05:09 Go to previous messageGo to next message
Thanks, I'll take a look...
> Roland,
> -Chris
> Roland Tepp wrote:
>> Hi Chris,
>> with the screenshot this code produces, illustrating my problem.
>> bleeding through the border here at the corners of the PGroup, where
>> they should be white, they are red instead.
>> bit in image positioning flag, where the entire top area of the PGroup
>> gets painted red...
>>> Hi Roland,
>>> attach a picture?
>>> -Chris
>>> Roland Tepp wrote:
>>>> Hello,
>>>> effectively defeating the whole idea of having the border arount the
>>>> group content...
>> * Contributors:
>> * Creates a PGroup.
>> shell.pack();
>> shell.open ();
>> display.dispose ();
Roland Tepp
Re: PGroup (RectangleGroupStrategy) background color issue [message #26774 is a reply to message #19670] Tue, 06 February 2007 06:03 Go to previous message
is this only in CVS or do I also get this fix when downloading the jar,
because I see the same effect here with the jar I downloaded.
Tom
Chris Gross schrieb:
> Roland,
> -Chris
Re: PGroup (RectangleGroupStrategy) background color issue [message #571401 is a reply to message #19398] Mon, 04 December 2006 10:53 Go to previous message
Hi Roland,
picture?
-Chris
Roland Tepp wrote:
> Hello,
Re: PGroup (RectangleGroupStrategy) background color issue [message #571429 is a reply to message #19490] Mon, 04 December 2006 11:29 Go to previous message
Hi Chris,
painted red...
> Hi Roland,
> picture?
> -Chris
> Roland Tepp wrote:
>> Hello,
Roland Tepp
* Contributors:
* Creates a PGroup.
shell.pack();
shell.open ();
display.dispose ();
Re: PGroup (RectangleGroupStrategy) background color issue [message #571461 is a reply to message #19535] Mon, 04 December 2006 16:13 Go to previous message
Hi Roland,
-Chris
Roland Tepp wrote:
> Hi Chris,
> painted red...
>> Hi Roland,
>> a picture?
>> -Chris
>> Roland Tepp wrote:
>>> Hello,
>>> content...
> * Contributors:
> * Creates a PGroup.
> shell.pack();
> shell.open ();
> display.dispose ();
Re: PGroup (RectangleGroupStrategy) background color issue [message #571522 is a reply to message #19535] Tue, 05 December 2006 16:56 Go to previous message
Roland,
-Chris
Roland Tepp wrote:
> Hi Chris,
> painted red...
>> Hi Roland,
>> a picture?
>> -Chris
>> Roland Tepp wrote:
>>> Hello,
>>> content...
> * Contributors:
> * Creates a PGroup.
> shell.pack();
> shell.open ();
> display.dispose ();
Re: PGroup (RectangleGroupStrategy) background color issue [message #573166 is a reply to message #19670] Thu, 21 December 2006 05:09 Go to previous message
> Roland,
> -Chris
> Roland Tepp wrote:
>> Hi Chris,
>> gets painted red...
>>> Hi Roland,
>>> attach a picture?
>>> -Chris
>>> Roland Tepp wrote:
>>>> Hello,
>>>> group content...
>> * Contributors:
>> * Creates a PGroup.
>> shell.pack();
>> shell.open ();
>> display.dispose ();
Roland Tepp
Re: PGroup (RectangleGroupStrategy) background color issue [message #577384 is a reply to message #19670] Tue, 06 February 2007 06:03 Go to previous message
Tom
> Roland,
> -Chris
Previous Topic:[CompositeTable] 0.9.2.1 released
Next Topic:PGroup not redrawn correctly
Current Time: Sat Nov 08 21:56:09 EST 2025
Powered by FUDForum. Page generated in 0.05734 seconds
