Home » Language IDEs » C / C++ IDE (CDT) » CDT Ceditor toggling breakpoint by doubleclicking
CDT Ceditor toggling breakpoint by doubleclicking [message #202732] Thu, 11 October 2007 00:58 Go to next message
Hello All,
I have created a multipage editor (to work with c/c++ files) with page 1
being an object of CEditor.
I have also included an extension org.eclipse.ui.editorAction and action
BreakpointRulerActions.
With this i am able see toggle breakpoints options under Run menu.
I can also see the same options when i right-click on the ruler.
I am able to toggle breakpoints using the above menu items.
But i am not able to toggle breakpoints by double-clicking on the editor
margin.
The same is working when a file is opened in C/C++ editor, but not working
when the same file is opened in my multipage editor.
Please give me a hint to resolve this issue.
Thanks a lot for your time.
Thanks and regards
Raghavendra.
Re: CDT Ceditor toggling breakpoint by doubleclicking [message #202772 is a reply to message #202732] Thu, 11 October 2007 04:41 Go to previous messageGo to next message
Raghavendra wrote:
> Hello All,
> margin.
> working when the same file is opened in my multipage editor.
> Thanks and regards
> Raghavendra.
The ruler double click action must be contributed as an editorAction
with the special attribute
actionID="RulerDoubleClick"
See the org.eclipse.cdt.debug.ui plugin.xml for reference.
Anton Leherbauer
Wind River CDT Team, Austria
Re: CDT Ceditor toggling breakpoint by doubleclicking [message #202788 is a reply to message #202772] Thu, 11 October 2007 06:44 Go to previous messageGo to next message
Hello Anton,
Thanks for your time.
We have set the actionID="RulerDoubleClick" in our plugin.xml.
Still this does not work.
Correct me if i am wrong. Just got confused when you say "See the
org.eclipse.cdt.debug.ui plugin.xml for reference."
Do we need to look for plugin.xml of org.eclipse.cdt.debug.ui
Thanks and regards
Raghavendra.
Re: CDT Ceditor toggling breakpoint by doubleclicking [message #202852 is a reply to message #202788] Fri, 12 October 2007 04:50 Go to previous message
Raghavendra wrote:
> Hello Anton,
Yes that's what I meant, but I it seems you don't need to look at it.
I have no clue why it does not work. Again, you need to debug it.
AbstractTextEditor.getRulerMouseListener() might be a starting point.
Anton Leherbauer
Previous Topic:CDT CEditor typing preferences
Next Topic:Line Start editor command behavior
Current Time: Tue Nov 04 18:46:04 EST 2025
Powered by FUDForum. Page generated in 0.04341 seconds
