| Re:[ATL]Launching ATL programmatically [message #1621] |
Tue, 19 December 2006 03:12   |
Eclipse User  |
Originally posted by: dorazio.nicola.yahoo.it
Hi Freddy,
I look your example, but I don't know why my error came from.
Why java cannot resolve path if I see by debug that the value of
function input = amh.loadModel("IN", emfmm1, inputm_url.openStream());
are all ok? Why when the program goes into this function when it call
the class URI.class return a null value?
This is my console output
 org.eclipse.emf.ecore.plugin.EcorePlugin.resolvePlatformReso urcePath(EcorePlugin.java:132)
 org.eclipse.emf.ecore.resource.impl.URIConverterImpl.createP latformResourceInputStream(URIConverterImpl.java:538)
 org.eclipse.emf.ecore.resource.impl.URIConverterImpl.createI nputStream(URIConverterImpl.java:442)
 org.eclipse.emf.ecore.xmi.impl.XMLHandler.getPackageForURI(X MLHandler.java:1674)
 org.eclipse.emf.ecore.xmi.impl.XMLHandler.getFactoryForPrefi x(XMLHandler.java:1568)
 org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObjectByType (XMLHandler.java:717)
 org.eclipse.emf.ecore.xmi.impl.XMLHandler.createTopObject(XM LHandler.java:779)
 org.eclipse.emf.ecore.xmi.impl.XMLHandler.processElement(XML Handler.java:462)
 org.eclipse.emf.ecore.xmi.impl.XMIHandler.processElement(XMI Handler.java:65)
 org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHa ndler.java:449)
 org.eclipse.emf.ecore.xmi.impl.SAXWrapper.startElement(SAXWr apper.java:73)
 com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser .startElement(Unknown
Source)
 com.sun.org.apache.xerces.internal.impl.dtd.XMLDTDValidator. startElement(Unknown
Source)
 com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl.scanStartElement(Unknown
Source)
 com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerIm pl$ContentDispatcher.scanRootElementHook(Unknown
Source)
 com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl$FragmentContentDispatcher.dispatch(Unknown
Source)
 com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl.scanDocument(Unknown
Source)
 com.sun.org.apache.xerces.internal.parsers.XML11Configuratio n.parse(Unknown
Source)
Source)
	at  com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(U nknown
Source)
 com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser .parse(Unknown
Source)
	at javax.xml.parsers.SAXParser.parse(Unknown Source)
	at  org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl. java:140)
 org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doLoad(XMLRes ourceImpl.java:169)
 org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:977)
 org.atl.engine.repositories.emf4atl.ASMEMFModel.loadASMEMFMo del(ASMEMFModel.java:167)
 org.atl.eclipse.engine.AtlEMFModelHandler.loadModel(AtlEMFMo delHandler.java:77)
	at ATLExample.launchTransformation(ATLExample.java:64)
	at ATLExample.run(ATLExample.java:97)
	at Main.main(Main.java:21)
My transformation runs great by graphic interface... I don't know why
there is so much problem from java.
please help me..
Best regard
Nicola D'Orazio
| Re: [ATL]Launching ATL programmatically [message #1635 is a reply to message #1621] |
Tue, 19 December 2006 05:34    |
Eclipse User  |
Your problem seems to be that you run EMF outside of Eclipse but try to
have it resolve an Eclipse platform path nonetheless.
What is the path of the model you are trying to open?
Another solution would be to try one of the other
AtlEMFModelHandler.loadModel methods.
For instance, using an InputStream:
loadModel(name, metamodel, new FileInputStream("<file path>"))
Note that you may still want to use an EMF URI so that inter-model
references (e.g., for UML models using UML profiles) are resolved
correctly. However, you have to make sure not to use an Eclipse platform
path.
Frédéric Jouault
Nicola D'Orazio wrote:
> Hi Freddy,
> java.lang.NullPointerException
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
> Source)
>     at
> Source)
>     at
> Source)
>     at
> Source)
>     at
> Source)
>     at
> Source)
>     at
> Source)
>     at
> Source)
>     at
>  com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(U nknown Source)
>     at
> Source)
>     at
>     at
>     at
>     at
>     at
> please help me..
> Best regard
> Nicola D'Orazio
| Re: [ATL]Launching ATL programmatically [message #2782 is a reply to message #1648] |
Tue, 26 December 2006 07:11   |
Eclipse User  |
I extended the related Howto with links to discussions threads related
to this issue:
 http://wiki.eclipse.org/index.php/ATL_Howtos#How_do_I_launch _transformations_programmatically.3F
You may want to compare your approach to those discussed in these threads.
Additionally, there is now a link to Dennis'ATL command line tools,
which may better illustrate the situation than KM3Projector, which
actually runs in Eclipse.
Frédéric Jouault
> Frédéric Jouault wrote:
>> Hello,
>> to have it resolve an Eclipse platform path nonetheless.
> is a path located under the eclipse workspace
> I try it but the error is the same...
>> platform path.
> Sorry but I don't understand this part of the message
>> Frédéric Jouault
> Thank you for your reply
> Best regard
> Nicola D'Orazio
FUDForum. Page generated in 0.66530 seconds
