Home » Archived » BIRT » script at birt report...??
script at birt report...?? [message #202641] Thu, 23 November 2006 01:41
Originally posted by: keeling040982.yahoo.com
hai....
Could anyone tell me...
1. how to the "method validate" at the report parameter?
2. how different with "allow null value" and "allow blanks value"??
3. is that if passing parameter (eg:....id=?), then cannot have the script
for the same data set that retrieve parameter from
java(eg:...+params["stmt"])???
4. how different with the passing parameter and filtering of a data set???
5. if i write query for a data set and also script(beforeOpen method),
how the flow going on? will the script(eg:this.queryText="Select...")
overwrite the query??? or the query will overwrite the script????
Thanks you for trying help............ ^0^
Previous Topic:get the mysql query...
Next Topic:temporary table in birt???
Current Time: Sun Jul 27 07:15:43 EDT 2025
Powered by FUDForum. Page generated in 0.22859 seconds
