Home » Archived » DSDP - Mobile Tools for Java (MTJ) » Using Nokia SDK's in Eclipse
Using Nokia SDK's in Eclipse [message #19377] Wed, 09 May 2007 10:42
Originally posted by: ph50.oortcloud.co.uk
I've been trying to get a Nokia emulator working in Eclipse. After some
hours with EclipseMe I gave up and tried MTJ but I can't get it working
here either. Can anyone help?
When I try to run a Midlet, the emulator appears and then goes again
with the error below.
Setup:
Eclipse 3.2
EMF 2.2
MTJ 0.7
WTK 2.2
Nokia SDK: S60_2nd_FP2_MIDP_SDK installed into C:\WTK22\wtklib\devices
The device platform tab shows two entries, the WTK and a second unnamed
entry. The WTK entry shows the S60 device along with those bundled with
the WTK.
I am using the WTK entry from the Runtime Platform as the second entry
in throws an error.
If I switch to a WTK emulator I can run the midlet (just a hello
world)but the S60 emulator throws the following..
WARNING: Attribute value for MicroEdition-Configuration defined in JAR
manifest is not supported.
Emulator command:
C:\WTK22\wtklib\devices\S60_2nd_FP2_MIDP_SDK\bin\Epoc32\rele ase\winscw\udeb\hmidp80.exe
hello_world_midp_package.Hello_World_MIDP -classpath
c:\tmp\midp\MNokia.jar -descriptor c:\tmp\midp\MNokia.jad Hello_World_MIDP
dummy.exe -classpath c:\tmp\midp\MNokia.jar -StickyConsole =StackSize512
=StackSizeIncrement512 =HeapMin400K =HeapCapacity16M
+VerboseClassLoading +UseCompiler +TraceDebugger
com.symbian.midp.runtime.MIDletSuiteAMS
hello_world_midp_package.Hello_World_MIDP -jar c:\tmp\midp\MNokia.jar
java.io.IOException
- com.symbian.midp.runtime.NativeFile.open(), bci=8
- com.symbian.midp.runtime.Jar.open(), bci=2
- com.symbian.midp.runtime.MIDletSuiteAMS.initialize(), bci=126
- com.symbian.midp.runtime.MIDletSuiteAMS.run(), bci=2
- com.symbian.midp.runtime.MIDletSuiteAMS.main(), bci=15
Previous Topic:Resouce files
Next Topic:Using Nokia SDK's in Eclipse
Current Time: Sat Nov 01 23:39:06 EDT 2025
Powered by FUDForum. Page generated in 1.09098 seconds
