Home » Newcomers » Newcomers » Error when trying to compile Java programs
Error when trying to compile Java programs [message #202291] Thu, 29 March 2007 14:26 Go to next message
Originally posted by: harmonizedchaos.gmail.com
what does this mean and what do I do to fix it? any ideas would be greatly
appreciated!
"ERROR: JDWP Unable to get JNI 1.2 environment, jvm->GetEnv() return code
= -2
JDWP exit error AGENT_ERROR_NO_JNI_ENV(183):
[../../../src/share/back/util.c:820]"
Thanks in advance!
Re: Error when trying to compile Java programs [message #202539 is a reply to message #202291] Sat, 31 March 2007 00:48 Go to previous message
Originally posted by: irbull.cs.uvic.ca
This is a very strange error. I assume you are running Eclipse on Linux
(since the path in your error report looks like a linux path). What
version of the JVM are you using to run Eclipse? What Linux version do
you have.
I have seen Eclipse act strange when run on the GNU JVM. This may be
the problem.
cheers,
ian
> greatly appreciated!
> code = -2
> Thanks in advance!
Previous Topic:JUnit Called through Ant via Eclipse Hangs
Next Topic:Eclipse Workbench
Current Time: Wed Jul 23 04:01:21 EDT 2025
Powered by FUDForum. Page generated in 0.11720 seconds
