Home » Eclipse Projects » Eclipse Platform » CVS 1.11.4 + WSAD 5.1.1 questions
CVS 1.11.4 + WSAD 5.1.1 questions [message #202245] Thu, 26 February 2004 08:43 Go to next message
Hi, I don't quite know which version of eclipse IBM's WSAD 5.1.1 is
based on, but in that version, eclipse's CVS support is behaving oddly.
1. If you do a cvs import, 1.11.4 (on AIX) creates 1.1 and 1.1.1.1 as
the vendor branch. If you then bring such an imported module into the
workspace with "Create as Project" or "Create module".. eclipse's cvs
shows the version tag as 1.1.1.1 rather than 1.1 even though the latter
is the HEAD version. If you change it and commit it it does increment
the version as 1.2 -- so I suspect it's a display issue (I see the
1.1.1.1 tag next to the resource name on the tree browser on the left).
2. Switching file types fails if the path contains a file name with a
space in it. Unfortunately WSAD creates images and web content in a
folder called "Web Content" -- and attempting to invoke the switch file
type operation fails with "File name Content not found".
Any thoughts on this?
Thanks in advance.
ps. if you could cc your reply to sundar@ascent.com I'd appreciate it.
Re: CVS 1.11.4 + WSAD 5.1.1 questions [message #203215 is a reply to message #202245] Fri, 27 February 2004 14:36 Go to previous message
Neither of these are known issues so you should log bug reports.
Michael
> Thanks in advance.
Previous Topic:CVSException exploring HEAD
Next Topic:Making SWT work in a browser, Bug 37707
Current Time: Sun Nov 02 19:53:44 EST 2025
Powered by FUDForum. Page generated in 0.07933 seconds
