Home » Language IDEs » C / C++ IDE (CDT) » Removing project from Build All command
Removing project from Build All command [message #202201] Wed, 26 September 2007 02:44 Go to next message
Originally posted by: mba.cosmigo.ru
I've got two C++ projects, let's call them "Engine" and "Tool". "Engine"
is a set of sources we maintain to be used in other projects, but we
don't compile it to be any kind of library - we just use it as external
sources accessible via #include. On the other hand "Tool" is a normal
project which compiles to binary executable, it uses part of "Engine"
sources.
So I would like to have both projects open at the same time in Project
explorer. The problem is that i have neither Makefile for "Engine" nor
external build command fro it - because it should not be build at all.
I would like to use a "Build All" IDE command to build my "Tool" project
with "Engine" being opened at same time as well. But I don't like the
error messages I get for "Engine" project like "Exec error:Launching
failed" because of no build command is specified for it. Can I exclude
this project from "build all" or mark it somehow that is should not be
built?
Best regards
Mikhail Barg
ICQ: 132560784
Re: Removing project from Build All command [message #202210 is a reply to message #202201] Wed, 26 September 2007 09:38 Go to previous messageGo to next message
> built?
Why do you not provide a dummy Makefile (a single line "all:" in it should
be sufficient) or provide a special build command such as "true" (which does
nothing but reports success)?
Jens
Re: Removing project from Build All command [message #202219 is a reply to message #202210] Wed, 26 September 2007 10:14 Go to previous message
Hi Jens,
Thanks for the idea. I've come to dummy Makefile myself, but using of
"true" command seems more elegant to me.
>> built?
> Jens
Best regards
Mikhail Barg
ICQ: 132560784
Previous Topic:CDT Help system
Next Topic:Exporting External Launch Configurations
Current Time: Mon Nov 03 14:47:52 EST 2025
Powered by FUDForum. Page generated in 0.04899 seconds
