Home » Eclipse Projects » GEF » Why doesn't the Tool of a CombinedTemplateCreationEntry get used for drag and drop from the palette?
Why doesn't the Tool of a CombinedTemplateCreationEntry get used for drag and drop from the palette? [message #202176] Mon, 07 November 2005 10:14 Go to next message
Originally posted by: cmahoney.ca.ibm.com
In GMF, we have a mechanism to allow clients to contribute the creation tool
to be used for their palette entries. We want to support DND from the
palette generically. Basically, I want my template (or creation factory?)
to be the creation tool itself because the client may have overridden
something in the creation tool (e.g. createTargetRequest(),
performCreation()). I am in the process of writing a
AbstractTransferDropTargetListener which will use the creation tool to
create the new shape (I am returning the tool as the template in the
CombinedTemplateCreationEntry).
Is there a reason why it wasn't done this way? Another benefit of using the
creation tool is that it already has the selectAddedObject() logic and this
wouldn't need to be written in the TemplateTransferDropTargetListener (in
theory).
Unfortunately, there are no public methods on the creation tool for which I
can easily create the shape in the location where the user dragged the
mouse. I think I will have to mimic mouse events or make
createTargetRequest() public in my parent creation tool class to support
this. I don't really like these ideas, any other suggestions?
Cherie
Re: Why doesn't the Tool of a CombinedTemplateCreationEntry get used for drag and drop from the pale [message #202197 is a reply to message #202176] Mon, 07 November 2005 13:37 Go to previous messageGo to next message
There are usually no reasons to subclass the CreationTool except to allow
the user to press a Cancel button and abort the creation and dismiss some
dialog that was displayed. Almost everything else can be done in the
factory, editpolicy, or command.
We should be selecting the created part. That's a bug.
"Cherie Mahoney" <cmahoney@ca.ibm.com> wrote in message
news:dknqun$6f2$1@news.eclipse.org...
> Hello,
> tool
> the
> this
> theory).
> I
> Cherie
Re: Why doesn't the Tool of a CombinedTemplateCreationEntry get used for drag and drop from the pale [message #202200 is a reply to message #202176] Mon, 07 November 2005 13:46 Go to previous messageGo to next message
Originally posted by: none.unknown.com
CreationToolEntry, in its constructor, uses the CreationTool by default. If
you want to use another tool instead, use ToolEntry#setToolClass().
I
mouse.
I am not sure what you mean by this. This works just fine in the logic
example. The CreateRequest has the location information.
> Hello,
tool
the
this
> theory).
I
> Cherie
Re: Why doesn't the Tool of a CombinedTemplateCreationEntry get used for drag and drop from the pale [message #202225 is a reply to message #202197] Mon, 07 November 2005 14:30 Go to previous messageGo to next message
Thanks. I guess the main issue is that we are subclassing the CreationTools
to provide different create requests than the standard GEF CreateRequest. I
may have to make createTargetRequest() public in our top-level CreationTool
so I can get the request from there.
- Cherie
"Randy Hudson" <none@us.ibm.com> wrote in message
news:dko6tv$oni$1@news.eclipse.org...
> > Hello,
> > tool
factory?)
> > the
> > this
(in
> > theory).
which
> > I
> > Thanks,
> > Cherie
Re: Why doesn't the Tool of a CombinedTemplateCreationEntry get used for drag and drop from the pale [message #202231 is a reply to message #202225] Mon, 07 November 2005 15:32 Go to previous messageGo to next message
What is the extra data that you are putting in the request?
news:dko9vk$t77$1@news.eclipse.org...
> CreationTools
> I
> CreationTool
> - Cherie
Re: Why doesn't the Tool of a CombinedTemplateCreationEntry get used for drag and drop from the pale [message #202267 is a reply to message #202231] Mon, 07 November 2005 17:48 Go to previous messageGo to next message
Randy,
We're subclassing CreateRequest to identify different classifications of
create requests, primarily whether to create the underlying model element
and/or the diagram shape/connection. Our CreateRequests carry data
identifying the type of model element to be created and the type of diagram
shape/connection to be created. If a client needed more data in the
CreateRequest they would subclass our CreateRequest and the CreationTool
used by the palette. Maybe we could have accomplished this with a
CreationFactory, but we are not using these.
Some of our client CreationTools have probably been subclassed for the wrong
reason and instead an editpolicy should have been subclassed. However, I
still think there are valid reasons to override the CreationTool and this
behavior is also desired for the DND palette behavior. For example, we
overwrote performCreation() in the CreationTool to put the name of the shape
created on the diagram in edit mode instead of just selecting the shape. In
order to implement this same behavior after DND, I need to override
selectAddedObject() in the TemplateTransferDropTargetListener to do the
same. If our clients have subclassed CreationTool to select something
different after creation they would also need to override the
TemplateTransferDropTargetListener, but if the
TemplateTransferDropTargetListener delegates to the CreationTool then they
get this behavior in the DND for free.
I'm also coding for Eclipse now, so I'm trying to think more about where the
code should go (GEF or GMF). :-)
- Cherie
news:dkodkq$2qr$1@news.eclipse.org...
> > CreationTools
CreateRequest.
> > I
> > CreationTool
> > - Cherie
Re: Why doesn't the Tool of a CombinedTemplateCreationEntry get used for drag and drop from the pale [message #202284 is a reply to message #202267] Mon, 07 November 2005 22:15 Go to previous message
news:dkoliv$drm$1@news.eclipse.org...
> Randy,
> diagram
It sounds like you could have put this extra info in the object type
parameter of the factory by making it some compound object. Or basically,
the type would be "model" or "view" or "model and connections", etc.
> wrong
> shape
> In
Using the creation tool for DND does not sound like the right thing. The
tool is a state machine for normal mouse events and there aren't any during
DND. Maybe you want something separated out from both the droptarget and the
tool for post-creation processing. But it sounds easy enough to duplicate
the behavior in two places.
> the
Great!
Previous Topic:Remove model objects or remove visuals?
Next Topic:Tooltip on Tree items #2
Current Time: Tue Jul 22 12:54:06 EDT 2025
Powered by FUDForum. Page generated in 0.03828 seconds
