| EVL and EMF editor integration ? [message #19322] |
Tue, 02 June 2009 15:15  |
Hi list,
I'm making a tool to generate schema definition text-file from a model
instance (for those of you who know Symfony, it's all about sfDoctrine
plug-in schema tooling).
I'm currently coding a validation file but I don't know how to call it
from the EMF editor. Is this possible yet ?
I thought about coding a wizard which would do the call, but I don't know
if there is a "standard" way or if this is the standard way.
I'd like to have it "integrated" in the EMF editor by right-clicking like
Wizard and not having to get somewhere else to have the validation process
launched (like using ANT tasks or such, if available; but still if not
possible yet, I'll go this way for now ;-).
By EMF Editor, I mean the editor which is created dynamically or not when
clicking "Create a dynamic instance" from the EMF Ecore model file.
| Re: EVL and EMF editor integration ? [message #19413 is a reply to message #19322] |
Wed, 03 June 2009 08:16   |
Originally posted by: myemail.server.com
Hi Stéphane,
Apologies for the delayed response.
To integrate with the EMF editor, you should follow the process outlined in
http://epsilonlabs.wiki.sourceforge.net/EVL-GMF+Integration
It's the same for EMF and GMF editors as EVL hooks into the EMF
validation framework that underpins both. Then, to invoke validation,
you should right-click on the root of your model in the EMF tree-based
editor and click "Validate".
Dimitris
Stéphane wrote:
> Hi list,
> know if there is a "standard" way or if this is the standard way.
> like Wizard and not having to get somewhere else to have the validation
> process launched (like using ANT tasks or such, if available; but still
> if not possible yet, I'll go this way for now ;-).
> when clicking "Create a dynamic instance" from the EMF Ecore model file.
| Re: EVL and EMF editor integration ? [message #568742 is a reply to message #19322] |
Hi Stéphane,
Dimitris
Stéphane wrote:
> Hi list,
FUDForum. Page generated in 0.03439 seconds
