Home » Archived » BIRT » make the query dynamic???
make the query dynamic??? [message #202032] Mon, 20 November 2006 22:07 Go to next message
Originally posted by: keeling040982.yahoo.com
hi...
i am using the birt2.1.1 to design my report template and using the
jbossIDE1.5 with the eclipse3.0 to run my system togather with the
jboss-4.0.2
now i wish to display the data in my report based on the filter that i
declare at the ".java"...
how can i make the query in the birt dynamic?? means that i can filter the
report data as i wish like limit the report date>1/11/2006 or report date
between 1/10/2006 and 1/11/2006 and so on...
what i done is,
at the birt2.1.1, i write the query like "select * from inventory";
at the ".java" where i make the filter, i pass the query as i wish like
"select * from inventory where date>1/11/2006"
but when i run whole system, the report will display all the data as the
query in the birt2.1.1 ("select * from inventory")...the data display in
report is not filter by the date>1/11/2006...
anyone can help me??? thanks....
Re: make the query dynamic??? [message #202056 is a reply to message #202032] Tue, 21 November 2006 02:05 Go to previous messageGo to next message
Originally posted by: karthi_mit.rrediffmail.com
Use Parameters.
Re: make the query dynamic??? [message #202070 is a reply to message #202056] Tue, 21 November 2006 02:47 Go to previous messageGo to next message
hai...KP...
thanks for your suggestion by using the parameter to make the query
dynamic.
could you please show me the clearly way how to make it??
i try to make the query dynamic, where i define at the beforeOpen method
as below:
this.quereyText="Select * from sp_inventory " + params["UPDATE_ON"];
but i still can't get the filtering for my data in the report.
is that i forgot any step???
thanks...
Re: make the query dynamic??? [message #202121 is a reply to message #202070] Tue, 21 November 2006 07:59 Go to previous messageGo to next message
Originally posted by: karthi.rediffmail.com
ok . Write ur query as like select * from inventory where inventory_id = ?
Then in the design of the report , add a parameter.
Define a default value , say for eg % .
Then while calling the report , u attach the parameter value.
If u hav any value then that will be considered , if not default value
will be taken.
Try this.
Kp
Re: make the query dynamic??? [message #202286 is a reply to message #202121] Tue, 21 November 2006 19:11 Go to previous messageGo to next message
hai KP...
but now the problem is i not using the birt viewer to view the report.
when i run my whole system, i am using the java to pass the parameter...
as your reference, i am using:
birt 2.1.1
eclipse3.0
jbossIDE1.5
jboss-4.0.2
so how can i get the parameter that i wish to pass as a filter for the
report from the java into the birt report query?? i can pass it into the
report but the birt report cant get it as the filter...
what have i done is, i call the beforeOpen method to call the query as:
this.queryText="select....+[param....];
but still have the problem to filter the report data as i wish...
any ideas on it????
thanks ya~
Re: make the query dynamic??? [message #202351 is a reply to message #202286] Wed, 22 November 2006 02:29 Go to previous message
In the query string u need to attach the parameter along with the value
while calling the report.
Previous Topic:cannot find parameter names in DataSetParameters of ODA data source
Next Topic:Slow dataset definition
Current Time: Sun May 11 10:27:21 EDT 2025
Powered by FUDForum. Page generated in 0.03737 seconds
