Home » Language IDEs » C / C++ IDE (CDT) » Error in remote debugging multi-thread program
| Error in remote debugging multi-thread program [message #201948] |
Thu, 20 September 2007 05:29  |
Originally posted by: samsheng.trident.com.cn
I got an error message during remote debugging a multi-thread process using
cdt.
It says:
An internal error occurred during: "child count update".
-1
The detail scenario is:
Eclipse version: 3.3RC1 for Linux
CDT version: 4.0.0 M7
GDB version: 6.5 (cross platfrom client + server)
The process on target has two threads.
I set break points in both thread functions.
After process running, the first thread got caught, and I do operation
"Step Over".
If the focus stays in first thread, everything is OK;
If the the first thread lost focus, Eclipse will show error message box with
message:
-1
Any help is appreciated.
Following is the source files:
makefile
all:threads install
threads: thread-func.c multi-thread.c
mips_lexra_fp_be-gcc -g -Wall $^ -o $@ -lpthread
install:
cp threads /opt/rootfs/debug/
clean:
rm -f threads
multi-thread.c
#include <stdio.h>
#include <unistd.h>
#include <stdlib.h>
#include <pthread.h>
#include "multi-thread.h"
extern void * thread_func0(void *arg);
extern void * thread_func1(void *arg);
int
main(int argc, char **argv)
int retVal = 0, index = 0;
int numThreads;
pthread_t thid[100];
numThreads = 2;
/*create all the threads*/
index = 0;
printf("Creating thread num %d\n", index);
retVal = pthread_create(&thid[index], NULL, thread_func0, (void *)&index);
if (retVal < 0) {
printf("Error in creating thread id %ld\n", thid[index]);
sleep(1);
index++;
retVal = pthread_create(&thid[index], NULL, thread_func1, (void *)&index);
if (retVal < 0) {
sleep(1);
for (index = 0; index < numThreads; index++) {
pthread_join(thid[index],NULL);
while(1)
sleep(1);
multi-thread.h
#ifndef MULTITHREAD2_H_
#define MULTITHREAD2_H_
#define MAXTRIES 2000
typedef struct struct_share{
unsigned int p0;
unsigned int p1;
}share_struct;
#endif /*MULTITHREAD2_H_*/
thread-func.c
#include <stdio.h>
#include <unistd.h>
static share_struct ss;
void *
unsigned int *p;
int i=0;
p = &(ss.p0);
for (;i < MAXTRIES;i++) {
if( ss.p0 > 1 + ss.p1 ) /* break point here*/
printf("P0:P0 loops times is %d more than P1\n",ss.p0-ss.p1);
(*p)++;
sleep(2);
return NULL;
void *
unsigned int *p;
int i=0;
p = &(ss.p1);
if(ss.p1> 1 + ss.p0) /* break point here*/
printf("P1:P1 loops times is %d more than P0\n",ss.p1-ss.p0);
(*p)++;
sleep(2);
return NULL;
Any comments are welcome!
Thanks!
Sam
| Re: Error in remote debugging multi-thread program [message #202377 is a reply to message #201948] |
Mon, 01 October 2007 04:45  |
This problem is solved by version:
http://www.eclipse.org/downloads/download.php?file=/technolo gy/epp/downloads/release/20070927/eclipse-cpp-europa-fall-li nux-gtk.tar.gz&r=1&protocol=http
Thanks for your attention!
Sam
"Sam Sheng" <samsheng@trident.com.cn>
Wrote:fcteh1$3pg$1@build.eclipse.org...
> Hello,
> using
> cdt.
> It says:
> -1
> "Step Over".
> with
> message:
> -1
> makefile
> all:threads install
> install:
> clean:
> rm -f threads
> multi-thread.c
> #include <stdio.h>
> #include <unistd.h>
> #include <stdlib.h>
> int
> int numThreads;
> numThreads = 2;
> index = 0;
> if (retVal < 0) {
> sleep(1);
> index++;
> if (retVal < 0) {
> sleep(1);
> while(1)
> sleep(1);
> multi-thread.h
> unsigned int p0;
> unsigned int p1;
> }share_struct;
> thread-func.c
> #include <stdio.h>
> #include <unistd.h>
> void *
> unsigned int *p;
> int i=0;
> p = &(ss.p0);
> (*p)++;
> sleep(2);
> return NULL;
> void *
> unsigned int *p;
> int i=0;
> p = &(ss.p1);
> (*p)++;
> sleep(2);
> return NULL;
> Thanks!
> Sam
Current Time: Wed Dec 03 13:22:10 EST 2025
Powered by FUDForum. Page generated in 0.03297 seconds
