Home » Language IDEs » C / C++ IDE (CDT) » CDT Help system
CDT Help system [message #201857] Tue, 18 September 2007 08:25 Go to next message
Originally posted by: pelle2004.gmail.com
I like to know what the full capacity of Eclipse when it comes to the help
system.
For instance I would like to have the opportunity in the CDT-Editor to
mark a glibc
function and hit F1/Help and end up in the explanation of that function.
const struct timeval tp,tzp;
settimeofday (&tp, &tzp);
Just mark or stand above 'settimeofday' and hit help should end up in a
glibc-section
inside the local help system. Contents of that should be a copy of
' http://www.gnu.org/software/libc/manual/html_mono/libc.html# High_002dResolution-Calendar'
So my question are...
- Is it already possible
- Where can I find information, web-links...
- Is there any help project/plug-ins, web-links...
- If not any extension points for a plug-in.
/Pelle
Re: CDT Help system [message #201884 is a reply to message #201857] Wed, 19 September 2007 03:42 Go to previous messageGo to next message
Pelle Svensson wrote:
> help system.
> mark a glibc
> glibc-section
> /Pelle
It is possible if you extend the "org.eclipse.cdt.ui.CHelpProvider"
extension point and implement the interface ICHelpProvider which
provides documentation and links for a particular function.
Basically it burns down to creating a mapping between function name and
documentation/links and some Java code to lookup the data.
Anton Leherbauer
Wind River CDT Team, Austria
Re: CDT Help system [message #202040 is a reply to message #201884] Mon, 24 September 2007 04:50 Go to previous messageGo to next message
On Wed, 19 Sep 2007 09:42:20 +0200, Anton Leherbauer
>> help system.
>> mark a glibc
>> a glibc-section
>> /Pelle
Ok,
Other question is if there are glibc and cpp/stl sections inside Eclipse's
help.
Has any-one converted GNU's help to Eclipse format?
Using Opera's revolutionary e-mail client: http://www.opera.com/mail/
Re: CDT Help system [message #202107 is a reply to message #202040] Tue, 25 September 2007 14:21 Go to previous messageGo to next message
> Ok,
> Eclipse's help.
We can't do this because the GNU man pages and other documentation are
GPL licensed, which is not compatible with the EPL license we use at
Eclipse.org
Chris Recoskie
Team Lead, IBM CDT Team
IBM Toronto
http://www.eclipse.org/cdt
Re: CDT Help system [message #202204 is a reply to message #202107] Wed, 26 September 2007 04:50 Go to previous messageGo to next message
Originally posted by: paul.mcconkey.net
> We can't do this because the GNU man pages and other documentation are GPL
> Eclipse.org
Presumably the license incompatibility just means that Eclipse.org wouldn't
be able to distribute the Eclipsified man pages. It would be fine for
someone to make a GPL version of the man pages and to distribute them for
others to use.
I'd use them for sure.
Paul.
Re: CDT Help system [message #202213 is a reply to message #202204] Wed, 26 September 2007 09:36 Go to previous message
>> Eclipse.org
> others to use.
> Cheers,
> Paul.
Yes... someone could do a Sourcforge project or whatever. It's
definitely a useful feature and it would get wide usage. Maybe someone
could contribute this to Redhat or one of the other Linux distros that
are bundling CDT.
Chris Recoskie
IBM Toronto
Previous Topic:Usage of External Settings Provider Extension
Next Topic:Removing project from Build All command
Current Time: Sat Nov 15 13:02:45 EST 2025
Powered by FUDForum. Page generated in 0.05805 seconds
