MBS extension: build variable don't include header files [message #201767] |
Mon, 17 September 2007 12:00  |
I use tools that generate source and header files. I want yo use the
extension capability of the MBS 4.0 to include these tools in my tool
chain. In order to manage dependency problems, I stored the generated
files in a build variable (buildVariable field of the Output Type).
However the header files are not included in the variables in the makefiles.
Is this a normal behavior of MBS?
best regards,
Gaetan MORICE
Re: MBS extension: build variable don't include header files [message #202082 is a reply to message #201814] |
Tue, 25 September 2007 04:15  |
>> makefiles.
>> best regards,
>> Gaetan MORICE
> The headers are not built, so they are only used in dependency rules,
> which you will find in the .d files.
> Chris Recoskie
> Team Lead, IBM CDT Team
> IBM Toronto
> http://www.eclipse.org/cdt
I agree, but in the project I am working on, the header files are
generated from other files. As a consequence the first time they don't
exists and the command to generate .d files fails. That's why I want to
use build variables and a special task defined with the prebuildStep
option of the Configuration in order to force the header files
generation before the build and enable .d files generation.
Gaétan MORICE
Solutions & Technologies
ANYWARE TECHNOLOGIES
www.anyware-tech.com
FUDForum. Page generated in 0.04090 seconds
