Home » Archived » DSDP - Real-Time Software Components (RTSC) » runtime initialization of statically created and constructed instances
runtime initialization of statically created and constructed instances [message #1616] Wed, 11 March 2009 13:46 Go to next message
Champs,
In my module's <<Mod>>_Module_startup() function, I have the following loop to complete the runtime initialization of all statically created instances.
/* do runtime init on all statically created objects */
for (i = 0; i < RcmServer_Object_count(); i++) {
h = RcmServer_Object_get(NULL, i);
* complete runtime initialization
Will this loop also give me the statically *constructed* instances?
~ Ramsey
Re: runtime initialization of statically created and constructed instances [message #1693 is a reply to message #1616] Mon, 16 March 2009 11:14 Go to previous messageGo to next message
Ramsey Harris wrote:
> Champs,
> instances.
No. Constructed instances can be constructed/destructed in real-time
using the stack for the instance object, for example.
> Thanks
> ~ Ramsey
Re: runtime initialization of statically created and constructed instances [message #1863 is a reply to message #1693] Mon, 16 March 2009 12:36 Go to previous message
>> Champs,
>> instances.
>> Thanks
>> ~ Ramsey
What if ModA's instance object has an embedded ModB instance object and ModA's instance is statically created? How do I initialize the constructed ModB instance object contained in ModA's instance object?
Previous Topic:Is there handle up-casting in meta-domain?
Next Topic:When can a module configure itself?
Current Time: Fri Nov 07 13:35:44 EST 2025
Powered by FUDForum. Page generated in 0.02695 seconds
