Home » Language IDEs » Java Development Tools (JDT) » Problem with OSGi class loader: Hibernate is not able to load class
Problem with OSGi class loader: Hibernate is not able to load class [message #201656] |
Thu, 21 April 2005 14:45  |
I want to use Hibernate in one of my plug-ins. Hibernate needs to load a
class using java.lang.ClassLoader.loadClass(String) for compiling the
mapping document.
I have this code in my start(BundleContext) method of the plug-in class
extending Plugin:
TestCase temp = new TestCase(null, null, null);
Configuration cfg = new Configuration()
.configure(hibernateConfigFile.toFile())
.addClass(TestCase.class)
It's no problem to create the instance "temp" in the first line of the
code snippet, the execution reaches the next line without any error. So,
I think the class loader is able to find the class TestCase...
But if the addClass(Class) method is called, the plug-in throws the
following Exception: [see below]
Can someone help me with this problem? I have no clue how to solve this.
In the first line, the plug-in finds the class, in the next one it does
not...
Martin
org.hibernate.MappingException: class
org.deltadebugging.ddchange.eclipse.core.junit.internal.resu lt.TestCase
not found while looking for property: id
org.hibernate.util.ReflectHelper.reflectedPropertyClass(Refl ectHelper.java:81)
org.hibernate.mapping.SimpleValue.setTypeUsingReflection(Sim pleValue.java:254)
at org.hibernate.cfg.HbmBinder.bindSimpleId(HbmBinder.java:359)
org.hibernate.cfg.HbmBinder.bindRootPersistentClassCommonVal ues(HbmBinder.java:293)
at org.hibernate.cfg.HbmBinder.bindRootClass(HbmBinder.java:235 )
at org.hibernate.cfg.HbmBinder.bindRoot(HbmBinder.java:151)
at org.hibernate.cfg.Configuration.add(Configuration.java:360)
at org.hibernate.cfg.Configuration.addInputStream(Configuration .java:397)
at org.hibernate.cfg.Configuration.addClass(Configuration.java: 465)
org.deltadebugging.ddchange.eclipse.core.CorePlugin.start(Co rePlugin.java:82)
org.eclipse.osgi.framework.internal.core.BundleContextImpl$1 .run(BundleContextImpl.java:958)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:954)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:937)
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:421)
org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:293)
org.eclipse.core.runtime.adaptor.EclipseClassLoader.findLoca lClass(EclipseClassLoader.java:110)
org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleLoader.java:371)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:402)
org.eclipse.osgi.framework.adaptor.core.AbstractClassLoader. loadClass(AbstractClassLoader.java:93)
at java.lang.ClassLoader.loadClass(ClassLoader.java:235)
org.eclipse.osgi.framework.internal.core.BundleLoader.loadCl ass(BundleLoader.java:307)
org.eclipse.osgi.framework.internal.core.BundleHost.loadClas s(BundleHost.java:336)
org.eclipse.osgi.framework.internal.core.AbstractBundle.load Class(AbstractBundle.java:1313)
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:131)
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:124)
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:113)
org.eclipse.jdt.internal.junit.ui.JUnitPlugin.loadTestRunLis teners(JUnitPlugin.java:382)
org.eclipse.jdt.internal.junit.ui.JUnitPlugin.getTestRunList eners(JUnitPlugin.java:415)
org.eclipse.jdt.internal.junit.ui.TestRunnerViewPart.startTe stRunListening(TestRunnerViewPart.java:691)
org.eclipse.jdt.internal.junit.ui.JUnitPlugin.connectTestRun ner(JUnitPlugin.java:208)
org.eclipse.jdt.internal.junit.ui.JUnitPlugin$2.run(JUnitPlu gin.java:269)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:106)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:2750)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2435)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1377)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1348)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:254)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:141)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:96)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:335)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:273)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:129)
at org.eclipse.core.launcher.Main.basicRun(Main.java:185)
at org.eclipse.core.launcher.Main.run(Main.java:704)
at org.eclipse.core.launcher.Main.main(Main.java:688)
Caused by: java.lang.ClassNotFoundException:
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:404)
at java.lang.ClassLoader.loadClassInternal(ClassLoader.java:302 )
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Class.java:141)
at org.hibernate.util.ReflectHelper.classForName(ReflectHelper. java:108)
org.hibernate.util.ReflectHelper.reflectedPropertyClass(Refl ectHelper.java:77)
... 50 more
Re: Problem with OSGi class loader: Hibernate is not able to load class [message #201666 is a reply to message #201656] |
Thu, 21 April 2005 15:15   |
Originally posted by: chaves.inf.no.ufsc.spam.br
This is a very f.a.q. You should be able to find the answer by searching
the newsgroups. For instance:
http://www.eclipse.org/search/search.cgi?q=hibernate+classlo ading+classloader
Martin Burger wrote:
> Hello,
> mapping document.
> extending Plugin:
> not...
> Martin
> at
> at
> at
> at
> at
> at
> at java.security.AccessController.doPrivileged(Native Method)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 50 more
Re: Problem with OSGi class loader: Hibernate is not able to load class [message #201674 is a reply to message #201666] |
Thu, 21 April 2005 15:17   |
Also:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=87775
>> Hello,
>> a class using java.lang.ClassLoader.loadClass(String) for compiling
>> the mapping document.
>> class extending Plugin:
>> So, I think the class loader is able to find the class TestCase...
>> this. In the first line, the plug-in finds the class, in the next one
>> it does not...
>> Regards,
>> Martin
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> at
>> at
>> at
>> at
>> at
>> at
>> ... 50 more
Re: Problem with OSGi class loader: Hibernate is not able to load class [message #201898 is a reply to message #201889] |
Sun, 24 April 2005 04:45   |
On Sun, 24 Apr 2005 07:06:14 +0200, Rafael Chaves
<chaves@inf.no.ufsc.spam.br> wrote:
> Max Rydahl Andersen wrote:
>> On Sat, 23 Apr 2005 19:35:10 +0200, Rafael Chaves
>>> You *can* pack Hibernate as a plug-in. The challenge is that
>>> Hibernate assumes it can find user classes in the current context
>>> classloader, and that is not the case in Eclipse (a plug-in has a
>>> very well defined classpath).
>> I would like to add that this is very correct behavior for any other
>> environment
>> than eclipse ;)
> This is probably related to the fact that Eclipse manages classloading
> so heavy-handedly, but execution flows freely across plug-ins. So
> Eclipse cannot enforce threads to have the expected context classloader.
> If Eclipse was in charge of calling plug-ins (IoC) and intercepting
> cross-plug-in interactions (as an EJB server might be able to do), that
> could be enforced.
yes this is correct and to work in non-j2ee, like j2se environments we
fallback to Class.forName() but that also doesnt work since if you bundle
hibernate as a separate plugin then it wont be able to see the classes
of the plugins that uses the hibernate plugin.
Eclipses (or OSGI's) classloading is something very different than any
other classloading mechanism and hence one will have trouble with alot
of frameworks out there that dynamically instantiates classes - from the
top of my head log4j custom appenders, xerces custom xml parser dom impl,
hibernate helper/user classes, any runtime AOP, jdbc drivers, etc.
the list is long....
>>> This is cumbersome, and the PR I mentioned in my other post is
>>> intended to address that problem.
>> I missed that one ? what was it ?
> Here it is:
a ok - that is the bug im already monitoring - thanks anyway.
/max
Re: Problem with OSGi class loader: Hibernate is not able to load class [message #201905 is a reply to message #201889] |
Sun, 24 April 2005 04:46  |
You *can* pack Hibernate as a plug-in. The challenge is that Hibernate
assumes it can find user classes in the current context classloader, and
that is not the case in Eclipse (a plug-in has a very well defined
classpath).
environment
than eclipse
This is probably related to the fact that Eclipse manages classloading so
heavy-handedly, but execution flows freely across plug-ins. So Eclipse
cannot enforce threads to have the expected context classloader. If
cross-plug-in
interactions (as an EJB server might be able to do), that could be
enforced.
This is cumbersome, and the PR I mentioned in my other post is intended
Here it is:
/max
Current Time: Tue Jul 22 13:09:48 EDT 2025
Powered by FUDForum. Page generated in 0.04534 seconds
