Home » Archived » BIRT » Slow dataset definition
Slow dataset definition [message #201566] Fri, 17 November 2006 04:49 Go to next message
When I use BIRT report designer (2.1.1) to connect to a big database
with a lot of shemas an tables, the table definition dialog is very slow.
Somebody else is experiencing with this problem? Is there any workaround?
Thank you,
Paolo Di Tommaso
Re: Slow dataset definition [message #201793 is a reply to message #201566] Mon, 20 November 2006 03:26 Go to previous messageGo to next message
> Thank you,
> Paolo Di Tommaso
Paolo,
What database are you using? I have only experienced this on Oracle.
John
Re: Slow dataset definition [message #201954 is a reply to message #201566] Mon, 20 November 2006 11:59 Go to previous messageGo to next message
Paolo,
How many schema/tables are in your database? You may want to consider
using the dialog found at:
Windows => Preferences => Report Design => Data Set Editor
=> JDBC Data Set
Once there you can change the Maximum number of schemas to display and
Maximum number of tables in each scheme to display.
The downside is that you will have to start to use the filter dialog to
pick the tables you want.
Scott Rosenbaum
> Thank you,
> Paolo Di Tommaso
Re: Slow dataset definition [message #202367 is a reply to message #201793] Wed, 22 November 2006 03:58 Go to previous message
I'm using Oracle .. !
Anyway Scott have suggested me to use the "Maximum number of schemas to
display" option in the JDBC Data Set preference page.
This solve in some way the problem.
Paolo
>> Thank you,
>> Paolo Di Tommaso
> Paolo,
> John
Previous Topic:make the query dynamic???
Next Topic:Integrating Reports with Application
Current Time: Wed Nov 19 00:13:53 EST 2025
Powered by FUDForum. Page generated in 0.03730 seconds
