Newbie question about resource.rc file [message #201540] |
Thu, 13 September 2007 11:15  |
Originally posted by: edstrasser.hotmail.com
I'm new to Eclipse and C++. I believe my issue is with Eclipse, please
correct me if I'm wrong.
The problem is that my program only displays a generic icon instead of the
custom icon I've defined. I believe that maybe I haven't told Eclipse
where to locate the .ico file and this is causing it not to display.
Below are my code files:
// RESOURCE.H
#define IDI_MYICON 101
// WINDOWSFORM.RC
#include "resource.h"
#include <windows.h>
IDI_MYICON ICON "U:\Etronics\Documents\Icon\32x32.ico"
// WINDOWFORM.CPP
const char g_szClassName[] = "myWindowClass";
// Step 4: the Window Procedure
LRESULT CALLBACK WndProc(HWND hwnd, UINT msg, WPARAM wParam, LPARAM lParam)
switch(msg)
case WM_CLOSE:
DestroyWindow(hwnd);
break;
case WM_DESTROY:
PostQuitMessage(0);
break;
default:
return DefWindowProc(hwnd, msg, wParam, lParam);
return 0;
int WINAPI WinMain(HINSTANCE hInstance, HINSTANCE hPrevInstance,
LPSTR lpCmdLine, int nCmdShow)
WNDCLASSEX wc;
HWND hwnd;
MSG Msg;
//Step 1: Registering the Window Class
wc.cbSize = sizeof(WNDCLASSEX);
wc.style = 0;
wc.lpfnWndProc = WndProc;
wc.cbClsExtra = 0;
wc.cbWndExtra = 0;
wc.hInstance = hInstance;
// wc.hIcon = LoadIcon(NULL, IDI_APPLICATION);
wc.hIcon = LoadIcon(hInstance, MAKEINTRESOURCE(IDI_MYICON));
wc.hCursor = LoadCursor(NULL, IDC_ARROW);
wc.hbrBackground = (HBRUSH)(COLOR_WINDOW+1);
wc.lpszMenuName = NULL;
wc.lpszClassName = g_szClassName;
wc.hIconSm = LoadIcon(NULL, IDI_APPLICATION);
if(!RegisterClassEx(&wc))
MessageBox(NULL, "Window Registration Failed!", "Error!",
MB_ICONEXCLAMATION | MB_OK);
return 0;
// Step 2: Creating the Window
hwnd = CreateWindowEx(
WS_EX_CLIENTEDGE,
g_szClassName,
"Etronics, Inc.",
WS_OVERLAPPEDWINDOW,
CW_USEDEFAULT, CW_USEDEFAULT, 240, 120,
NULL, NULL, hInstance, NULL);
if(hwnd == NULL)
MessageBox(NULL, "Window Creation Failed!", "Error!",
return 0;
ShowWindow(hwnd, nCmdShow);
UpdateWindow(hwnd);
// Step 3: The Message Loop
while(GetMessage(&Msg, NULL, 0, 0) > 0)
TranslateMessage(&Msg);
DispatchMessage(&Msg);
return Msg.wParam;
Re: Newbie question about resource.rc file [message #201557 is a reply to message #201540] |
Thu, 13 September 2007 11:30  |
> Eclipse where to locate the .ico file and this is causing it not to
> display.
It's more complicated, you must "compile" your icon to a library like
"libIcon.a". See http://www.gnu.org/software/binutils/ for "Windres" the
"Compiler for Windows resource files". For execution "windres" you need
to install MSYS I think. After that you can use the MSYS bash for
something like "windres MyIcon.rc libicon.a" and then use eclipse
properties to link "icon" into your software.
HTH,
Ed
FUDForum. Page generated in 0.03388 seconds
