| About BPMN'layout [message #201476] |
Mon, 11 August 2008 23:02 |
Originally posted by: stephenbyc.gmail.com
I'm studying the source of BPMN. I want to modify the layout of
diagram to vertical as which horizontal originally.
Following, I found that it is not via set layout in the
diagram'editpart to constraint the pool but install a layout policy
which named BpmnDiagramXYLayoutE , Then, I try to modify it. Finally, I
make the layout vertical, however the width of the margin which figures
to the pool contains it, is still as before. The problem has been
puzzling me for three days! Anyone can help me to solve it.
Thank you very much!
Stephen
FUDForum. Page generated in 0.03558 seconds
