Home » Language IDEs » ServerTools (WTP) » problem with "org.eclipse.wst.server.core.launchableAdapters"
problem with "org.eclipse.wst.server.core.launchableAdapters" [message #201312] Fri, 05 October 2007 04:35
Hai,
If I register new extention in
"org.eclipse.wst.server.core.launchableAdapters" eclipse always picks up
only one adapter for one server. For example in tomcat55 I need a
launchable object with some extra information. But its always taking
HTTPLaunchable. not a customized one.
I have analyzed inside code I found the following in
org.eclipse.wst.server.ui.internal.actions.RunOnServerAction Delegate
/ get the launchable adapter and module object
ILaunchableAdapter launchableAdapter = null;
Object launchable = null;
ILaunchableAdapter[] adapters = ServerPlugin.getLaunchableAdapters();
if (adapters != null) {
int size2 = adapters.length;
for (int j = 0; j < size2; j++) {
ILaunchableAdapter adapter = adapters[j];
try {
Object launchable2 = adapter.getLaunchable(server, moduleArtifact);
Trace.trace(Trace.FINEST, "adapter= " + adapter + ", launchable= " +
launchable2);
if (launchable2 != null) {
launchableAdapter = adapter;
launchable = launchable2;
} catch (Exception e) {
Trace.trace(Trace.SEVERE, "Error in launchable adapter", e);
i.e it picks only the last adapter. Why it is? What can I do if I want to
add my own custom adapter for existing server ids?
is it a bug?
Sundar
Previous Topic:XML Editor: No Error hint in the Design View
Next Topic:64 Bit Compatibility
Current Time: Sat Jul 26 10:02:03 EDT 2025
Powered by FUDForum. Page generated in 0.21871 seconds
