Home » Archived » BIRT » Parameter passing in BIRT Report Through JSP
Parameter passing in BIRT Report Through JSP [message #200890] Tue, 14 November 2006 23:59 Go to next message
Originally posted by: mani_rana.yahoo.com
I have created charts using BIRT, the chart report runs successfully in
Eclipse using the BIRT report viewer. There are two report parameters that
are used to produce the charts.
The report also run successfully through JSP code as follows:
EngineConfig engineConfig = new EngineConfig();
engineConfig.setEngineHome("F:\\birt-runtime-2_1_1\\ReportEngine ");
ReportEngine engine = new ReportEngine(engineConfig);
IReportRunnable design = null;
try {
design =
engine.openReportDesign("F:\\workspace\\MyReports\\Charts.rptdesign ");
catch (EngineException e) {
e.printStackTrace();
IRunAndRenderTask task = engine.createRunAndRenderTask(design);
try{
HTMLRenderOption options = new HTMLRenderOption();
javax.servlet.ServletOutputStream sosStream = null;
sosStream = response.getOutputStream();
options.setOutputStream(sosStream);
task.setRenderOption(options);
catch(java.lang.Exception e){
try{
task.run();
}catch (EngineException e) {
out.println(e.getMessage());
engine.destroy();
The report uses two parameters, but it always takes the default values.
Now I want to pass the value of the parameter from the JSP code. Please
help.
Thanks in advance.
Re: Parameter passing in BIRT Report Through JSP [message #201051 is a reply to message #200890] Wed, 15 November 2006 14:50 Go to previous messageGo to next message
You should be able to set parameters in your code using the task.
Like
String name = "Top Count";
Integer pvalue = new Integer(4);
parameters.put(name, pvalue);
task.setParameterValues(parameters);
//Alternatively set each seperately
//task.setParameterValue("Top Count", new Integer(12));
task.validateParameters();
If you are using the BIRT Viewer they are passed as name value pairs on the
url.
&parmname=parmvalue.
Jason
"mani" <mani_rana@yahoo.com> wrote in message
news:f1aab63246e6668e75e1018475e5eee3$1@www.eclipse.org...
> try {
> design =
> try{
> try{
> task.run();
> engine.destroy();
> help.
> Thanks in advance.
Re: Parameter passing in BIRT Report Through JSP [message #201141 is a reply to message #201051] Wed, 15 November 2006 23:48 Go to previous messageGo to next message
Thanks for your quick response Jason.
I added the following code after line
"IRunAndRenderTask task = engine.createRunAndRenderTask(design);" : -
String name = "startDateTime";
HashMap parameters = new HashMap();
Here startDateTime is a report parameter. I get the following exception: -
exception
org.apache.jasper.JasperException: getOutputStream() has already been
called for this response
org.apache.jasper.servlet.JspServletWrapper.handleJspExcepti on(JspServletWrapper.java:510)
org.apache.jasper.servlet.JspServletWrapper.service(JspServl etWrapper.java:387)
org.apache.jasper.servlet.JspServlet.serviceJspFile(JspServl et.java:314)
org.apache.jasper.servlet.JspServlet.service(JspServlet.java :264)
javax.servlet.http.HttpServlet.service(HttpServlet.java:802)
root cause
java.lang.IllegalStateException: getOutputStream() has already been called
for this response
org.apache.catalina.connector.Response.getWriter(Response.ja va:606)
org.apache.catalina.connector.ResponseFacade.getWriter(Respo nseFacade.java:195)
org.apache.jasper.runtime.JspWriterImpl.initOut(JspWriterImp l.java:124)
org.apache.jasper.runtime.JspWriterImpl.flushBuffer(JspWrite rImpl.java:117)
org.apache.jasper.runtime.PageContextImpl.release(PageContex tImpl.java:191)
org.apache.jasper.runtime.JspFactoryImpl.internalReleasePage Context(JspFactoryImpl.java:115)
org.apache.jasper.runtime.JspFactoryImpl.releasePageContext( JspFactoryImpl.java:75)
org.apache.jsp.Mani.jsp3_jsp._jspService(org.apache.jsp.Mani .jsp3_jsp:227)
org.apache.jasper.runtime.HttpJspBase.service(HttpJspBase.ja va:97)
org.apache.jasper.servlet.JspServletWrapper.service(JspServl etWrapper.java:332)
But if I set any arbitrary variable like the same you have used "Top
Count", the report runs successfully.
Please let me know your suggestions.
Mani
Re: Parameter passing in BIRT Report Through JSP [message #201296 is a reply to message #201141] Thu, 16 November 2006 13:18 Go to previous messageGo to next message
Try doing the validate parameters call after you use the task to set the
parameter.
BTW is your parameter type set as a date type?
Jason
news:a6e01a3971fbbafb729da75326da6233$1@www.eclipse.org...
> I added the following code after line "IRunAndRenderTask task =
> exception
> root cause
> for this response
> Mani
Re: Parameter passing in BIRT Report Through JSP [message #201856 is a reply to message #201296] Mon, 20 November 2006 05:00 Go to previous message
Thanks Jason (for the DateTime hint). Yes, the parameter is of DateTime
Type. My problem is solved now, I was not setting the parameter to
DateTime. Now the following code works fine:
Format formatter;
formatter = new SimpleDateFormat("dd/MM/yyyy HH:mm:ss aaa");
Date date = new Date("10/03/2006 12:00:00 AM");
parameters.put(name, date);
Thanks a lot for your help.
-Mani
Previous Topic:Printing Report when clicking "Print report as PDF"
Next Topic:retrieve parameter from address bar to birt report
Current Time: Thu Jul 17 17:28:37 EDT 2025
Powered by FUDForum. Page generated in 0.08746 seconds
