Home » Archived » Visual Editor (VE) » Problem running VE 0.5.0
Problem running VE 0.5.0 [message #19140] Mon, 16 February 2004 13:10 Go to next message
Originally posted by: tobias.kastl.freenet.de
Hello @everyone!
I tried the VE under Win2k and was enthusiastic. So I tried to install it
under Linux (Debian Kernel 2.6.1, eclipse 2.1.2, GEF-runtime-I20031015,
emf_1.1.1_20031020_1612WL.zip) too. The installation succeeded, but, when
I try to create a new VisualClass I get a NullPointerException and the
logfile shows the following Information:
!SESSION Feb 16, 2004 19:05:58.530
java.version=1.4.2_03
BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=en_US
Command-line arguments: -os linux -ws gtk -arch x86 -install
file:/usr/share/eclipse/
!ENTRY org.eclipse.ve.java.core 4 0 Feb 16, 2004 19:05:58.532
!MESSAGE Exception
!STACK 0
at org.eclipse.core.runtime.CoreException.<init>(CoreException.java:35)
org.eclipse.jem.internal.proxy.core.ProxyPlugin.exec(ProxyPl ugin.java:414)
org.eclipse.jem.internal.proxy.core.ProxyVMRunner.exec(Proxy VMRunner.java:20)
org.eclipse.jdt.internal.launching.StandardVMRunner.run(Stan dardVMRunner.java:230)
org.eclipse.jem.internal.proxy.remote.ProxyRegistration.star tImplementation(ProxyRegistration.java:206)
org.eclipse.jem.internal.proxy.core.ProxyPlugin.startImpleme ntation(ProxyPlugin.java:165)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart.createProxyFactoryRegistry(JavaVisualEditorPart.jav a:667)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$Setup.initializeForProject(JavaVisualEditorPart.jav a:1800)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$Setup.initialize(JavaVisualEditorPart.java:1705)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$Setup.run(JavaVisualEditorPart.java:1588)
at java.lang.Thread.run(Thread.java:534)
I already did a chmod on the installation directory.
So, could you please help me and tell me, where I did wrong.
Thank you very much,
best wishes,
Tobi
Re: Problem running VE 0.5.0 [message #19217 is a reply to message #19140] Mon, 16 February 2004 13:52 Go to previous messageGo to next message
Originally posted by: richkulp.NO.SPAM.us.ibm.com
Looking in the code the null pointer exception occurred because we had
trapped an IOException and was trying to turn it into a CoreException,
except we made mistake and had some bad code.
The basic problem is that we were trying to do a:
Runtime.getRuntime().exec(...)
and an IOException was thrown.
Unfortunately we lost what the actual I/O exception was that actually
happened.
Something about your setup prevented us from doing an exec() line.
Since this code is not that much different then the standard java
application launcher used by straight Eclipse, try this:
1) Create a class with a main
2) Use Launch As Java Application against this class.
See if the standard launcher will have an I/O exception too and print
off what the problem was.
Thanks, Rich Kulp
Re: Problem running VE 0.5.0 [message #19228 is a reply to message #19217] Mon, 16 February 2004 16:36 Go to previous messageGo to next message
Back again,
thank you very much for your answer,
I did as you suggested and got another Exception trying to run a normal
Application.
Here comes the stacktrace:
!SESSION Feb 16, 2004 22:34:30.948
file:/usr/share/ecl
ipse/
!ENTRY org.eclipse.debug.ui 4 120 Feb 16, 2004 22:34:30.950
!MESSAGE Error logged from Debug UI:
!STACK 1
org.eclipse.core.runtime.CoreException[120]: java.io.IOException:
java.io.IOExce
ption: /usr/share/j2sdk1.4.2_03/bin/java: cannot execute
at java.lang.UNIXProcess.<init>(UNIXProcess.java:143)
at java.lang.Runtime.execInternal(Native Method)
at java.lang.Runtime.exec(Runtime.java:566)
at org.eclipse.debug.core.DebugPlugin.exec(DebugPlugin.java:471 )
org.eclipse.jdt.launching.AbstractVMRunner.exec(AbstractVMRu nner.java
:59)
ner.java:230)
org.eclipse.jdt.internal.launching.JavaLocalApplicationLaunc hConfigur
ationDelegate.launch(JavaLocalApplicationLaunchConfiguration Delegate.java:111)
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConf
iguration.java:156)
org.eclipse.debug.internal.ui.DebugUIPlugin.buildAndLaunch(D ebugUIPlu
gin.java:676)
org.eclipse.debug.ui.DebugUITools.buildAndLaunch(DebugUITool s.java:53
8)
at org.eclipse.debug.ui.DebugUITools$2.run(DebugUITools.java:48 7)
org.eclipse.jface.operation.ModalContext$ModalContextThread. run(Modal
Context.java:101)
!ENTRY org.eclipse.debug.core 4 120 Feb 16, 2004 22:34:30.951
!MESSAGE Exception occurred executing command line.
!STACK 0
java.io.IOException: java.io.IOException:
not execute
:59)
ner.java:230)
iguration.java:156)
gin.java:676)
8)
Context.java:101)
I think we're on the right way but I'm afraid I still don't know where to
go. ;)
Be so kind and do another suggestion.
best wishes, Tobi
> happened.
Re: Problem running VE 0.5.0 [message #19246 is a reply to message #19228] Mon, 16 February 2004 16:40 Go to previous message
Ha! After reading what I posted I found out what was missing.
I changed the access-rights for the eclipse-installation, but not for my
j2sdk.
There was the problem. After chmodding the sdk-directory it worked.
Thank you very much for your help,
bye, bye,
Tobi
Tobi wrote:
> Back again,
> Application.
> file:/usr/share/ecl
> ipse/
> !STACK 1
> java.io.IOExce
> at
> :59)
> at
> ner.java:230)
> at
> at
> iguration.java:156)
> at
> gin.java:676)
> at
> 8)
> at
> Context.java:101)
> !STACK 0
> not execute
> at
> :59)
> at
> ner.java:230)
> at
> at
> iguration.java:156)
> at
> gin.java:676)
> at
> 8)
> at
> Context.java:101)
> go. ;)
> best wishes, Tobi
> > happened.
Re: Problem running VE 0.5.0 [message #581297 is a reply to message #19140] Mon, 16 February 2004 13:52 Go to previous message
happened.
Thanks, Rich Kulp
Re: Problem running VE 0.5.0 [message #581315 is a reply to message #19217] Mon, 16 February 2004 16:36 Go to previous message
Back again,
Application.
file:/usr/share/ecl
ipse/
!STACK 1
java.io.IOExce
:59)
ner.java:230)
iguration.java:156)
gin.java:676)
8)
Context.java:101)
!STACK 0
not execute
:59)
ner.java:230)
iguration.java:156)
gin.java:676)
8)
Context.java:101)
go. ;)
best wishes, Tobi
> happened.
Re: Problem running VE 0.5.0 [message #581337 is a reply to message #19228] Mon, 16 February 2004 16:40 Go to previous message
j2sdk.
bye, bye,
Tobi
Tobi wrote:
> Back again,
> Application.
> file:/usr/share/ecl
> ipse/
> !STACK 1
> java.io.IOExce
> at
> :59)
> at
> ner.java:230)
> at
> at
> iguration.java:156)
> at
> gin.java:676)
> at
> 8)
> at
> Context.java:101)
> !STACK 0
> not execute
> at
> :59)
> at
> ner.java:230)
> at
> at
> iguration.java:156)
> at
> gin.java:676)
> at
> 8)
> at
> Context.java:101)
> go. ;)
> best wishes, Tobi
> > happened.
Previous Topic:Problem running VE 0.5.0
Next Topic:having install problems with VE
Current Time: Mon Jul 14 09:33:22 EDT 2025
Powered by FUDForum. Page generated in 0.27826 seconds
