Home » Newcomers » Newcomers » how to read chars from console
how to read chars from console [message #200621] Tue, 20 March 2007 03:01 Go to next message
Originally posted by: yuyingtina.tom.com
I am working on an eclipse plugin about console.
I want to get chars from keyboard in the created console ,
and output it in the console.
the problem lies on the code
" IOConsoleInputStream stream = console.getInputStream();
byte[] b=new byte[5];
stream.read(b); //here is the problem "
the programm is hangging in this line.
Addition,I can write to the output stream and the text will appear on the
console.
but couldn't write and read chars from the keyboard.
Here is my code :
import java.io.*;
import org.eclipse.ui.console.*;
import org.eclipse.core.runtime.IProgressMonitor;
import org.eclipse.core.runtime.IStatus;
import org.eclipse.core.runtime.jobs.Job;
public class ConsoleViewPart implements IConsoleFactory {
private static IOConsole console = new IOConsole("IOconsole",
null,null);
public void openConsole() {
showConsole();
public static void showConsole() {
if (console != null) {
IConsoleManager manager =
ConsolePlugin.getDefault().getConsoleManager();
IConsole[] existing = manager.getConsoles();
boolean exists = false;
for (int i = 0; i < existing.length; i++) {
if (console == existing[i])
exists = true;
if(!exists){
System.out.println("hello");
manager.addConsoles(new IConsole[] { console });
manager.showConsoleView(console);
try {
stream.read(b); // here is the problem
IOConsoleOutputStream out=console.newOutputStream();
out.write(b);
System.setOut(new PrintStream(out));}
catch (IOException e) {
e.printStackTrace();
public static void closeConsole() {
manager.removeConsoles(new IConsole[] { console });
public static IOConsole getConsole() {
return console;
Re: how to read chars from console [message #200646 is a reply to message #200621] Tue, 20 March 2007 07:46 Go to previous message
I'm waiting for you to help me ,thanks!
Previous Topic:Getting diff of changes per checkin on Eclipse CVS repository ?
Next Topic:Any plugin for bash scripting?
Current Time: Thu Oct 30 19:18:22 EDT 2025
Powered by FUDForum. Page generated in 0.08864 seconds
