| Exception in eclipse report designer on scripted data source preview results [message #200527] |
Mon, 13 November 2006 11:02  |
I'm getting the below exception when I use a very simple scripted
datasource... this started happening after I upgraded my birt report
designer plugin in eclipse from version 2.1.0 to 2.1.1.
The error message is:
An unexpected internal exception occurred.Please see log for detail.
Plug-in Provider:EclipseUI
Plug-in ID:org.eclipse.birt.report.designer.ui
Version:2.1.1.v20060922-1058
Error Code:Error.GUIException.invokedByUnexpectedException
Error Message:Caused by java.lang.reflect.InvocationTargetException
Any help would be appreciated.
PS. this works outside of eclipse, e.g. when I generate reports with a
script using the report engine API.
Salome
FUDForum. Page generated in 0.04561 seconds
