Home » Eclipse Projects » Subversive » 0.7.0.v20080307 fails be to be installed form a local site
0.7.0.v20080307 fails be to be installed form a local site [message #19131] Tue, 20 May 2008 15:06 Go to next message
Originally posted by: aleksey.barabashov.ubs.com
In Eclipse 3.3.2 (also tried 3.3.0) when installing Subversive as
described at your manual I am getting this:
Subversive Integration for the Mylyn Project (Optional) (Incubation)
(0.7.0.v20080517) requires feature "org.eclipse.team.svn
(0.7.0.v20080307)", or compatible.
Subversive SVN Connectors (2.0.0.v20080517) requires feature
"org.eclipse.team.svn (0.7.0.v20080517)", or compatible.
I am using the two official zip files you have on the project front page.
Subversive-incubation-0.7.0.v20080517.zip
Subversive-connectors-2.0.0.v20080517.zip
Tried as archived and as local sites with no luck. Was selecting both of
them.
I have to use a local site approach to get Subversive installed on other
developers PCs.
I actually got Subversive working by unpacking the zips into the Eclipse
directory but that messed us features configuration in Eclipse so that is
not an option.
Thanks in advance!
Re: 0.7.0.v20080307 fails be to be installed form a local site [message #19134 is a reply to message #19131] Tue, 20 May 2008 17:39 Go to previous messageGo to next message
Juts got it installed from the Remote site with no issues. My guess is
that your archived site is broken.
Re: 0.7.0.v20080307 fails be to be installed form a local site [message #19344 is a reply to message #19131] Thu, 22 May 2008 06:12 Go to previous message
> them.
> developers PCs.
> not an option.
> Thanks in advance!
Hi, Aleksey.
Just tried both on 3.3.1 and 3.3.2.
Downloaded both archives and pointed freshly installed Eclipse
update-manager to this update-sites.
Everything works just fine.
Best regards, Alexei Goncharov.
Subversive Team
Previous Topic:using existing subtree copy
Next Topic:problems connecting to subversion repository using svn+ssh
Current Time: Wed Nov 05 08:12:25 EST 2025
Powered by FUDForum. Page generated in 0.04365 seconds
