Home » Language IDEs » C / C++ IDE (CDT) » How to start C project under Vista with Eclipse?
How to start C project under Vista with Eclipse? [message #200445] Tue, 28 August 2007 08:49 Go to next message
Hi all
I am a new guy tring to start C programming with Eclipse.I have Eclipse3.3.0
for Windows, cdt-master-4.0.0, and also I have installed MimGW-5.1.3 under
C:\MinGW, and added system path "C:\MinGW\bin". When I was building a sample
c project, it resulted:
**** Build of configuration Debug for project helloWorld ****
**** Internal Builder is used for build ****
gcc -O2 -g -Wall -c -fmessage-length=0 -ohello.o ..\hello.c
gcc: installation problem, cannot exec `cc1': No such file or directory
Build error occurred, build is stopped
Time consumed: 282 ms.
Anyboday could help to fix this? Thanks in advance. The OS is Vista home
basic
Dominic
Re: How to start C project under Vista with Eclipse? [message #200493 is a reply to message #200445] Tue, 28 August 2007 09:06 Go to previous messageGo to next message
exquisitus wrote:
> Hi all
> Eclipse3.3.0 for Windows, cdt-master-4.0.0, and also I have installed
> MimGW-5.1.3 under C:\MinGW, and added system path "C:\MinGW\bin". When I
> was building a sample c project, it resulted:
> basic
> Dominic
I'm not overly familiar with MinGW, but it looks like an installation
problem. Either your MinGW install went bad, or you are missing packages.
Chris Recoskie
Team Lead, IBM CDT Team
IBM Toronto
http://www.eclipse.org/cdt
Re: How to start C project under Vista with Eclipse? [message #200511 is a reply to message #200493] Tue, 28 August 2007 09:29 Go to previous messageGo to next message
Hi Chris
I am not sure whether I have correct installation of MinGW.I have tried many
ways of different configuration, and the logs are the recent result. Is
there any default c or c++ compiler embeded in Eclipse for windows? Eclipse
is much more open, but I should add CDT,MinGW,etc, that brings confusion.
And when I search on the Internet for "gcc: installation problem, cannot
exec `cc1': No such file or directory", some people say that this issure has
something to do with Vista. I do not know. And if I want to start the first
c++/c project with eclipse, what configuration should I make? I donot think
the Eclipse.org web page and the eclipse help in the IDE present clearly.
Thanks and wait on line.
"Chris Recoskie" <recoskie@ca.ibm.com> 写入消息
news:fb16m8$992$5@build.eclipse.org...
> exquisitus wrote:
>> Hi all
>> basic
>> Dominic
> Chris Recoskie
> IBM Toronto
Re: How to start C project under Vista with Eclipse? [message #200541 is a reply to message #200511] Tue, 28 August 2007 10:42 Go to previous messageGo to next message
You might try the pre-built Eclipse+CDT+MinGW:
http://wascana.sourceforge.net/
....Beth
Re: How to start C project under Vista with Eclipse? [message #200604 is a reply to message #200541] Tue, 28 August 2007 16:08 Go to previous message
> ...Beth
Yes, the 0.9.2 release supports Vista. There is a magic patch required
for MinGW to resolve it's internal paths. I guess MicroSoft changed
something in the run-time that broke things.
Doug
Previous Topic:no debugging of C++ programs on linux?
Next Topic:managed make project
Current Time: Fri Nov 07 16:18:59 EST 2025
Powered by FUDForum. Page generated in 0.06665 seconds
