Home » Language IDEs » ServerTools (WTP) » Drag and drop into the SSE
Drag and drop into the SSE [message #200434] Mon, 24 September 2007 17:31 Go to next message
On the Europa release, when I drag and drop in the editor from the
navigator, It inserts it one less than where I drop it,
for example I start with:
<test id="test1"></test>
dnd from the navigator and dropping after the last > will give me
<test id="test1"></test"WebContent/NewFile4.xml">
this is what I expected (works in 1.x):
<test id="test1"></test>"WebContent/NewFile4.xml"
In 1.x of WTP I saw the expected behavior. Is this working as designed
or a bug. If the latter, let me know and Ill write it up.
Brian Jakubik
Re: Drag and drop into the SSE [message #200474 is a reply to message #200434] Tue, 25 September 2007 04:55 Go to previous messageGo to next message
It works fine with 3.4 M2, so strangely there was a change in
behavior in the base that fixes the problem for us but which doesn't
seem to affect the default drag and drop support either way. Our
own DND classes haven't been touched since before 2.0 was released,
but changes in when StyledText.getOffsetAtLocation(Point) throws
Exceptions might be responsible. Please open a bug, but it's not
catastrophic enough for 2.0.1 at this point.
Nitin Dahyabhai
Structured Source Editing
Re: Drag and drop into the SSE [message #200632 is a reply to message #200474] Wed, 26 September 2007 12:12 Go to previous message
Thanks Nitin, Bug 204703 has been added to the database.
> It works fine with 3.4 M2, so strangely there was a change in behavior
> in the base that fixes the problem for us but which doesn't seem to
> affect the default drag and drop support either way. Our own DND
> classes haven't been touched since before 2.0 was released, but changes
> in when StyledText.getOffsetAtLocation(Point) throws Exceptions might be
> responsible. Please open a bug, but it's not catastrophic enough for
> Nitin Dahyabhai
Previous Topic:Completion XML schema
Next Topic:log4j.properties missing from exported war file
Current Time: Fri Sep 12 21:07:05 EDT 2025
Powered by FUDForum. Page generated in 0.03489 seconds
