Home » Archived » BIRT » passing JDBC parameter at runtime
passing JDBC parameter at runtime [message #200364] Fri, 10 November 2006 20:00 Go to next message
When I design a report, I create the dataset by configuring the JDBC
parameter. However, is it possible at run time, I would be able to send the
user id, password and schema information? Because that way, the report is
not bound to the hard-coded information.
Bidyut
Re: passing JDBC parameter at runtime [message #200407 is a reply to message #200364] Sat, 11 November 2006 16:34 Go to previous messageGo to next message
specify a JNDI name for the data source. That way you can configure your
database connection information in the servlet container that runs the
report instead of using the hard-coded parameters.
http://www.eclipse.org/birt/phoenix/project/notable2.1.php#j ump_4
http://tomcat.apache.org/tomcat-5.5-doc/jndi-datasource-exam ples-howto.html
HTH,
Jan
Bidyut Pattanayak wrote:
> Thanks
> Bidyut
Re: passing JDBC parameter at runtime [message #200568 is a reply to message #200364] Mon, 13 November 2006 11:38 Go to previous messageGo to next message
You can also use script or property binding to change the user, password,
driver and dburl on the fly.
Jason
"Bidyut Pattanayak" <bidyut@yahoo.com> wrote in message
news:ej37bi$h8c$1@utils.eclipse.org...
> the user id, password and schema information? Because that way, the report
> is not bound to the hard-coded information.
> Thanks
> Bidyut
Re: passing JDBC parameter at runtime [message #200626 is a reply to message #200568] Mon, 13 November 2006 19:00 Go to previous messageGo to next message
Thanks Jason. That sounds interesting. Is there any documentation you can
point me to, so that I can get a better idea about that.
Bidyut
"Jason Weathersby" <jweathersby@actuate.com> wrote in message
news:eja70t$bjl$1@utils.eclipse.org...
> Jason
>> report is not bound to the hard-coded information.
>> Thanks
>> Bidyut
Re: passing JDBC parameter at runtime [message #200634 is a reply to message #200626] Mon, 13 November 2006 19:24 Go to previous message
There is information on this page:
http://www.eclipse.org/birt/phoenix/deploy/reportScripting.p hp
Here are a few examples of how to swap url and user using property binding
or script.
Jason
news:ejb0ve$msb$1@utils.eclipse.org...
> Thanks
> Bidyut
>> Jason
>>> Hi,
>>> Thanks
>>> Bidyut
  • Attachment: examples.zip
    (Size: 55.75KB, Downloaded 96 times)
Previous Topic:Birt Designer into Rcp application
Next Topic:Instructions to run tests after checking out and building birt.
Current Time: Mon Sep 01 00:35:28 EDT 2025
Powered by FUDForum. Page generated in 0.03087 seconds
