Layout: How to modify TopDownProvider? [message #200239] |
Mon, 04 August 2008 18:40  |
Originally posted by: rolfes.daniel.web.de
i am trying to change the Layout of my diagram.
I want to achieve the following result:
I have two different connection types. If two nodes are connected with
the first type, there should be a top-down behavior. If they are
connected with the second type, there should be a left-right or
right-left behavior.
I tried to modify the TopDownProvider (DefaultProvider) but there is
some fancy stuff going on, involving the GMFDirectedGraphLayout.
Is this the right way to do this? Or does anyone know a better approach?
Daniel
Re: Layout: How to modify TopDownProvider? [message #200805 is a reply to message #200788] |
Wed, 06 August 2008 08:20   |
i should probably add that the user should be able to layout the
diagramm manually. The described behavior should be invoked by the
Arrange-all-button.
Daniel
D. Rolfes schrieb:
> i would be really glad, if you could give me some hints on this one. How
> do i start?
> D. Rolfes schrieb:
>> Thanks,
>> Daniel
Re: Layout: How to modify TopDownProvider? [message #201259 is a reply to message #200805] |
Fri, 08 August 2008 13:38  |
any help would be greatly appreciated!
Daniel
D. Rolfes schrieb:
> Arrange-all-button.
> Daniel
> D. Rolfes schrieb:
>> How do i start?
>> D. Rolfes schrieb:
>>> Hi,
>>> with the first type, there should be a top-down behavior. If they are
>>> Thanks,
>>> Daniel
FUDForum. Page generated in 0.29225 seconds
