Home » Archived » BIRT » configurable url
configurable url [message #200235] Fri, 10 November 2006 08:56 Go to next message
i'm new of birt...
I create a xml data source.
I insert my url in datasource. For example:
http://127.0.0.1:8080/Project/3450/readDocument
I create a data set and i can see the table map and all it's all right.
I see the document with id = 3450.
Now i want create a paramiter so that the user can insert the id and i can
create report that user want.
but, how can i do?
i try
http://127.0.0.1:8080/Project/&reportparamitername/readD ocument
but isn't correct...
someone can help me?
Re: configurable url [message #200269 is a reply to message #200235] Fri, 10 November 2006 10:34 Go to previous messageGo to next message
Where are you setting this?
It should have syntax like
"http://127.0.0.1:8080/Project/" + params["reportparamitername"] +
"/readDocument"
Jason
"Paolo" <pbellani@hotmail.com> wrote in message
news:b346804f547b5b218bbc08af7dfe65c2$1@www.eclipse.org...
> i'm new of birt...
> but, how can i do?
> i try http://127.0.0.1:8080/Project/&reportparamitername/readD ocument
Re: configurable url [message #200470 is a reply to message #200269] Mon, 13 November 2006 05:34 Go to previous messageGo to next message
I try but i receive this message...
Data (id = 358):
+ Cannot open the connection for the driver:
org.eclipse.birt.report.data.oda.xml
no protocol: "http://127.0.0.1:8080/Project/" +
params["reportparamitername"] + "/readDocument"
tnx
Re: configurable url [message #200543 is a reply to message #200470] Mon, 13 November 2006 11:20 Go to previous messageGo to next message
Can you post the report?
Jason
news:3b61db2e401de31b0d5bd90a58dd3a1c$1@www.eclipse.org...
> Data (id = 358): + Cannot open the connection for the driver:
> tnx
Re: configurable url [message #200723 is a reply to message #200543] Tue, 14 November 2006 05:35 Go to previous messageGo to next message
can you send me an email so i can send you report?
tnx
> Jason
>> tnx
Re: configurable url [message #200753 is a reply to message #200543] Tue, 14 November 2006 10:21 Go to previous messageGo to next message
<!-- Written by Eclipse BIRT 2.0 -->
<report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.2"
id="1">
<property name="createdBy">Eclipse BIRT Designer Version
2.1.0.N20060628-1351 Build &lt;20060628-1537></property>
<property name="units">mm</property>
<text-property name="title">Papela</text-property>
<property name="comments">Ciao mamma</property>
<parameters>
<scalar-parameter name="rp_idproto" id="342">
<property name="valueType">static</property>
<property name="dataType">string</property>
<property name="concealValue">false</property>
<property name="allowBlank">false</property>
<property name="allowNull">false</property>
<property name="controlType">text-box</property>
<structure name="format">
<property name="category">Unformatted</property>
</structure>
</scalar-parameter>
</parameters>
<data-sources>
<oda-data-source
extensionID="org.eclipse.birt.report.data.oda.xml"
name="datasourcesprotocolloxml" id="213">
<property
name="FILELIST">"http://127.0.0.1:8080/EdmaWeb/service/Proto/"+
params["rp_idproto"] + "/caricaDocumento"</property>
</oda-data-source>
</data-sources>
<data-sets>
<oda-data-set
extensionID="org.eclipse.birt.report.data.oda.xml.dataSet"
name="datasetspapelaxml" id="214">
<structure name="cachedMetaData">
<list-property name="resultSet">
<structure>
<property name="position">1</property>
<property name="name">identificatore</property>
</structure>
</list-property>
</structure>
<property name="dataSource">datasourcesprotocolloxml</property>
<property
name="queryText"> table0#-TNAME-#table0#:#[/it.lispa.edma.telemaco.po.Protocol lo]#:#{identificatore;String;/identificatore} </property>
<property name="MAX_ROW">-1</property>
</oda-data-set>
</data-sets>
<page-setup>
<simple-master-page name="Simple MasterPage" id="2">
<property name="leftMargin">22.86mm</property>
<property name="bottomMargin">17.991mm</property>
<property name="rightMargin">34.925mm</property>
<page-footer>
<text id="3">
<property name="contentType">html</property>
<text-property name="content"><![CDATA[<value-of>new
Date()</value-of>]]></text-property>
</text>
</page-footer>
</simple-master-page>
</page-setup>
<body>
<data id="359">
<property name="dataSet">datasetspapelaxml</property>
<list-property name="boundDataColumns">
<structure>
<expression
name="expression">dataSetRow["identificatore"]</expression >
</structure>
</list-property>
<property name="resultSetColumn">identificatore</property>
</data>
</body>
</report>
Re: configurable url [message #200785 is a reply to message #200753] Tue, 14 November 2006 11:36 Go to previous messageGo to next message
You are not building the url in the property binding for the xml data
source.
In the datasource hard code to an existing location and then change it in
the data binding property.
Take a look at this example:
Jason
id="1">
<property name="units">in</property>
<property name="comments">Copyright (c) 2006 &lt;&lt;Your Company Name
here>></property>
<list-property name="propertyBindings">
<structure>
<property name="name">FILELIST</property>
<property name="id">4</property>
<expression name="value">"http://localhost/" + params["xmllocation"]
+"/test.xml"</expression>
</structure>
<structure>
<property name="name">SCHEMAFILELIST</property>
</structure>
</list-property>
<parameters>
<scalar-parameter name="xmllocation" id="22">
<property name="defaultValue">xml1</property>
</structure>
</scalar-parameter>
</parameters>
<data-sources>
<oda-data-source extensionID="org.eclipse.birt.report.data.oda.xml"
name="Data Source" id="4">
<text-property name="displayName">Data Source</text-property>
<property name="FILELIST">http://localhost/xml1/test.xml</property>
</oda-data-source>
</data-sources>
<data-sets>
<oda-data-set extensionID="org.eclipse.birt.report.data.oda.xml.dataSet"
name="Data Set" id="5">
<text-property name="displayName">Data Set</text-property>
<structure>
<property name="name">name</property>
<property name="nativeDataType">12</property>
</structure>
<structure>
<property name="position">2</property>
<property name="name">nickname</property>
</structure>
</list-property>
<structure>
</structure>
<structure>
</structure>
</list-property>
</structure>
<property name="dataSource">Data Source</property>
<property
name="queryText"> table0#-TNAME-#table0#:#[/people/person/nicknames/nickname]# :#{name;String;../../name},{nickname;String;} </property>
<property name="XML_FILE">http://localhost/xml1/test.xml</property>
</oda-data-set>
</data-sets>
<page-setup>
<page-footer>
<text id="3">
</text>
</page-footer>
</page-setup>
<body>
<table id="6">
<property name="width">100%</property>
<property name="dataSet">Data Set</property>
<structure>
<expression name="expression">dataSetRow["name"]</expression>
</structure>
<structure>
<expression name="expression">dataSetRow["nickname"]</expression>
</structure>
</list-property>
<column id="20"/>
<column id="21"/>
<header>
<row id="7">
<cell id="8">
<label id="9">
<text-property name="text">name</text-property>
</label>
</cell>
<cell id="10">
<label id="11">
<text-property name="text">nickname</text-property>
</label>
</cell>
</row>
</header>
<detail>
<row id="12">
<cell id="13">
<data id="14">
<property name="resultSetColumn">name</property>
</data>
</cell>
<cell id="15">
<data id="16">
<property name="resultSetColumn">nickname</property>
</data>
</cell>
</row>
</detail>
<footer>
<row id="17">
<cell id="18"/>
<cell id="19"/>
</row>
</footer>
</table>
</body>
</report>
news:c93e17f7e3953ebc1330c24fc594e59b$1@www.eclipse.org...
> id="1">
> <parameters>
> </structure>
> </scalar-parameter>
> </parameters>
> <data-sources>
> <property
> </oda-data-source>
> </data-sources>
> <data-sets>
> <oda-data-set
> <structure>
> </structure>
> </list-property>
> </structure>
> <property
> </oda-data-set>
> </data-sets>
> <page-setup>
> <page-footer>
> <text id="3">
> </text>
> </page-footer>
> </page-setup>
> <body>
> <data id="359">
> <structure>
> <expression
> </structure>
> </list-property>
> </data>
> </body>
> </report>
Re: configurable url [message #200947 is a reply to message #200785] Wed, 15 November 2006 05:34 Go to previous messageGo to next message
tnx a lot!
i've only another question...
now i build the url in the property binding for the xml data
source.
but also if i enter the default in the paramiter i can't (in data set)
choose the table in table mapping... i see
"/it.lispa.rsi3.service.SystemException".
If i cut in datasource the binding i can map the table in dataset...
Not is a big problem but.. why it happen?
Re: configurable url [message #201001 is a reply to message #200947] Wed, 15 November 2006 12:45 Go to previous message
I am not sure I understand the problem.
Hardcode the default for design purposes.
Property binding replaces it at run time.
Jason
news:c31dc5192a0fc683c0834c52d1da7dbb$1@www.eclipse.org...
> tnx a lot!
> now i build the url in the property binding for the xml data source.
Previous Topic:How can i change dynamically a dataset ?
Next Topic:How to switch GUI language of BIRT Designer 2.1.1?
Current Time: Thu Sep 18 15:57:02 EDT 2025
Powered by FUDForum. Page generated in 0.05004 seconds
