Home » Eclipse Projects » Eclipse Platform » Eclipse under Tru64
Eclipse under Tru64 [message #200200] Mon, 23 February 2004 16:21 Go to next message
Originally posted by: javier.campoamor.net
I would like to use Eclipse in a Tru64 (old Compaq Unix OSF1) machine but I
have seen that there are versions for several Unixes but there is no version
for Tru64. Is there a document about the steps needed to port Eclipse to
another system?. Do you know how can this be done?
Thanks in advance,
Javier
Re: Eclipse under Tru64 [message #200512 is a reply to message #200200] Mon, 23 February 2004 21:45 Go to previous messageGo to next message
Originally posted by: pascal.rapicault.ibm
Try a search in the archives of this newsgroup.
Javier Campoamor wrote:
> Hello,
> Thanks in advance,
> Javier
Re: Eclipse under Tru64 [message #200852 is a reply to message #200200] Tue, 24 February 2004 08:58 Go to previous message
HI Javier,
If Tru64 is a 64-bit architecture (sorry I'm not familiar with it) then
Eclipse won't run on it yet. swt-gtk (and by extension, Eclipse) is being
made 64-bit clean though, and is planned for the 3.0 release.
If this machine will run in 32-bit mode then the porting steps are
described in:
http://dev.eclipse.org/viewcvs/index.cgi/%7Echeckout%7E/plat form-swt-home/faq.html#howbuilddll
http://dev.eclipse.org/viewcvs/index.cgi/%7Echeckout%7E/plat form-swt-home/faq.html#buildeclipseexe
(64-bit plan item: https://bugs.eclipse.org/bugs/show_bug.cgi?id=37721 )
Grant
> Hello,
> Thanks in advance,
> Javier
Previous Topic:Visual Editor plugin problem!
Next Topic:Incremental Compiler bug when accessing a protected attribute?
Current Time: Sun Aug 31 12:07:15 EDT 2025
Powered by FUDForum. Page generated in 0.03449 seconds
