Home » Archived » BIRT » Viewer running out of memory with large data sets
Viewer running out of memory with large data sets [message #200182] Fri, 10 November 2006 05:19 Go to next message
I'm creating a table with a data set of around 100,000 rows.
The report i created generates fine in the developer and i'm able to
preview it in HTML and PDF.
But when i deploy the report online with the BIRT-viewer application I'm
running into issues. To start with I'm using JBoss 4.0.1 on Windows . The
birt-viewer application is deployed in the serverdefaultdeploy directory
of my JBoss instillation.
When I run my report and limit my dataset to smaller sizes the page will
generate fine. But when I increase the range I get a pop up box giving an
exception.
The only error message in the box is:
java.lang.ClassCastException:java.lang.OutOfMemoryError
Stack trace: is blank
Is there any way to increase the memory size of the birt-viewer so i can
get the report to process?
Re: Viewer running out of memory with large data sets [message #200316 is a reply to message #200182] Fri, 10 November 2006 13:08 Go to previous messageGo to next message
You should be able to set the mem sizes for JBOSS in the run script.
Just look for the Xms and Xmx settings.
Jason
"Manuel" <usha.manuel@mybdr.com> wrote in message
news:1e94604907896d9a0e81ad9b07f6272a$1@www.eclipse.org...
> exception.
Re: Viewer running out of memory with large data sets [message #200424 is a reply to message #200316] Sun, 12 November 2006 17:45 Go to previous messageGo to next message
Hey,
Does this imply that the maximum size of a report is constrained by
available memory?
Shaun
> Jason
>> exception.
Re: Viewer running out of memory with large data sets [message #201075 is a reply to message #200424] Wed, 15 November 2006 14:56 Go to previous message
This model is being slightly changed for 2.1.2 (Feb 2007).
It currently caches data but I believe the report may be in memory.
2.1.2 should have a page at a time in memory, I believe.
Jason
"Shaun Forbes" <sforbes@sforbes.myip.org> wrote in message
news:ej886f$c8f$1@utils.eclipse.org...
> Hey,
> available memory?
> Shaun
>> Jason
>>> The birt-viewer application is deployed in the serverdefaultdeploy
>>> directory of my JBoss instillation.
>>> an exception.
Previous Topic:Comments on the readme.txt in BIRT runtime download
Next Topic:Report Viewer PDF Problem
Current Time: Sun Aug 31 13:35:03 EDT 2025
Powered by FUDForum. Page generated in 0.03602 seconds
