Home » Archived » BIRT » Report Viewer
Report Viewer [message #200090] Thu, 09 November 2006 16:14 Go to next message
Originally posted by: brad.lwsi.com
I have a report displayed in the Report Viewer. There are about like 100
records generated. How can I set it to display only 10 records at a time
in the listing? So in other words, there would be 10 pages of 10 records.
Thanks!
Re: Report Viewer [message #200114 is a reply to message #200090] Thu, 09 November 2006 20:37 Go to previous messageGo to next message
> Thanks!
I tried it using the Page Break Interval in the Table Property
but it didn't work.
The solution that worked for me was to add a new computed column
with the expression row["0"]/10. This creates a column with the
value 0 for the first 10 rows, 1 for the next 10 rows, etc.
Now you can use this new column as a group. Just set the page
break after group "Always Except Last" to make force a next page
after every group. This technique also allows you to have
page subtotals.
Re: Report Viewer [message #200174 is a reply to message #200114] Fri, 10 November 2006 04:51 Go to previous messageGo to next message
Hi Jjdscss,
I too have a similiar requirement. But i didnt understood the solution u
explained clearly... Could u please explain it again more ellobrately?
Regrds,
Manuel
Re: Report Viewer [message #200198 is a reply to message #200174] Fri, 10 November 2006 06:31 Go to previous messageGo to next message
Originally posted by: jgngo.yahoo.com
To do break a page by a certain number of rows, you need to do the
following steps:
1. In the Bindings tab of the table, add a new data binding with the
following parameters:
Data Type: Integer
Expression: row[0]/10
The value is 10 because we want to break a page by 10 rows each.
2. In the Groups tab, add a new group with the following parameters:
Group On: pagenum
Page break After: Always Excluding Last
That should give you the desired result.
Re: Report Viewer [message #202435 is a reply to message #200198] Wed, 22 November 2006 10:38 Go to previous message
Thanks Jason Ngo. Itz working fine for me
Previous Topic:Sending both Image(PNG) and ImageMaps from the server to the client
Next Topic:Making report show multiple screens/pages
Current Time: Sun Aug 31 12:27:56 EDT 2025
Powered by FUDForum. Page generated in 0.58178 seconds
