Home » Archived » Visual Editor (VE) » About a characteristic of VE.
About a characteristic of VE. [message #19094] Fri, 13 February 2004 02:52 Go to next message
Originally posted by: davidd.mapfre.es
Hi again!
I've a problem.
* I've a class named TFRame that extends from JFrame
* I create a TFrame instance with VE.
* When I click in the TFrame, VE opens and small and white text box that
permit me write a word and it assigns this word to the property 'title'.
* Some similar to this occurs with other components.
My question is:
Where can I delete this functionality?
I need that this property only change trought the properties sheet.
Thanks you!
Re: About a characteristic of VE. [message #19110 is a reply to message #19094] Fri, 13 February 2004 05:58 Go to previous messageGo to next message
Hi David,
I think this feature should just occur on double click. Does it occur on
single click for you ?
> My question is:
You can't delete it - please open a bugzilla to have it added to the
preferences page to enable/disable.
I looked at the code to see if you could disable it, however it is
hard-wired into the method getDirectEditTargetProperty in
ComponentGraphicalEditPart and createEditPolicies which uses this to create
an edit policy.
Joe
Re: About a characteristic of VE. [message #19114 is a reply to message #19110] Fri, 13 February 2004 09:05 Go to previous message
Fantastic!
Many thanks, now VE works as I need.
Joe Winchester wrote:
> Hi David,
> > My question is:
> an edit policy.
> Best regards,
> Joe
Re: About a characteristic of VE. [message #581076 is a reply to message #19094] Fri, 13 February 2004 05:58 Go to previous message
Hi David,
> My question is:
an edit policy.
Joe
Re: About a characteristic of VE. [message #581105 is a reply to message #19110] Fri, 13 February 2004 09:05 Go to previous message
Fantastic!
> Hi David,
> > My question is:
> an edit policy.
> Best regards,
> Joe
Previous Topic:Update VE via Update Manager
Next Topic:Update VE via Update Manager
Current Time: Sat Jul 12 12:01:59 EDT 2025
Powered by FUDForum. Page generated in 0.04469 seconds
