| About a characteristic of VE. [message #19094] |
Fri, 13 February 2004 02:52  |
Originally posted by: davidd.mapfre.es
Hi again!
I've a problem.
* I've a class named TFRame that extends from JFrame
* I create a TFrame instance with VE.
* When I click in the TFrame, VE opens and small and white text box that
permit me write a word and it assigns this word to the property 'title'.
* Some similar to this occurs with other components.
My question is:
Where can I delete this functionality?
I need that this property only change trought the properties sheet.
Thanks you!
| Re: About a characteristic of VE. [message #19114 is a reply to message #19110] |
Fri, 13 February 2004 09:05  |
Fantastic!
Many thanks, now VE works as I need.
Joe Winchester wrote:
> Hi David,
> I think this feature should just occur on double click. Does it occur on
> single click for you ?
> > My question is:
> You can't delete it - please open a bugzilla to have it added to the
> preferences page to enable/disable.
> I looked at the code to see if you could disable it, however it is
> hard-wired into the method getDirectEditTargetProperty in
> ComponentGraphicalEditPart and createEditPolicies which uses this to create
> an edit policy.
> Best regards,
> Joe
| Re: About a characteristic of VE. [message #581076 is a reply to message #19094] |
Fri, 13 February 2004 05:58  |
Hi David,
> My question is:
an edit policy.
Joe
| Re: About a characteristic of VE. [message #581105 is a reply to message #19110] |
Fantastic!
> Hi David,
> > My question is:
> an edit policy.
> Best regards,
> Joe
FUDForum. Page generated in 0.04110 seconds
