Home » Newcomers » Newcomers » Eclipse + Tomcat problem
Eclipse + Tomcat problem [message #200046] Sat, 17 March 2007 10:26 Go to next message
Originally posted by: lvw.tlen.pl
I've installed WTP Eclipse, and everything works well beside one matter:
when my servlet is saving a file by this code:
t.transform(new DOMSource(xmlDoc), new StreamResult(
new FileOutputStream("final.xml")));
the final.xml document is saved in the Eclipse main directory, how can I
adjust the properties to save this file in folder where the servlet is
running?
Thanks for answer.
Re: Eclipse + Tomcat problem [message #200468 is a reply to message #200046] Mon, 19 March 2007 11:55 Go to previous message
Originally posted by: wayne.beaton._NOSPAM_eclipse.org
Open the run configuration ("Run > Run..." from the menu and select your
configuration on the left). Switch to the "Arguments" tab and set the
"Working Directory".
As a general rule, writing a file from a servlet is a bad idea.
Especially one with an absolute name. What happens when two users hit
the servlet at the same time? Or 100?
HTH,
Wayne
Kanan wrote:
> when my servlet is saving a file by this code: t.transform(new
> DOMSource(xmlDoc), new StreamResult( new
> running?
> Thanks for answer.
Previous Topic:Eclipse on Windows x64?
Next Topic:Eclipse Errors - what am I doing wrong
Current Time: Mon Nov 03 01:30:27 EST 2025
Powered by FUDForum. Page generated in 0.08429 seconds
