Home » Newcomers » Newcomers » Problem with XMLConfiguration
Problem with XMLConfiguration [message #199985] Fri, 16 March 2007 21:19 Go to next message
Originally posted by: francuesta.gmail.com
Hello, I use a JAR file with XMLConfiratuion class (a reader of XML
files). I have a wizard that when uses this class. When I try to start,
Eclipse 3.2.2 tell me:
"The selected wizard could not be started"
"org/apache/commons/configuration/XMLConfiguration"
The same plug-in hadnŽt problems in Eclipse 3.1
I have tried to update libraries and the result was the same. If you can
help me with this problem I would be greated
Thank you so much!!!
Re: Problem with XMLConfiguration [message #200031 is a reply to message #199985] Sat, 17 March 2007 08:32 Go to previous messageGo to next message
Fran,
How have you made the jar available at runtime? Is it in its own
plugin. Are the packages that jar provides exported by the MANIFEST.MF
for that plugin?
> start, Eclipse 3.2.2 tell me:
> can help me with this problem I would be greated
Re: Problem with XMLConfiguration [message #200054 is a reply to message #200031] Sat, 17 March 2007 10:42 Go to previous messageGo to next message
I have 2 rar files with the implementation of XMLConfiguration and another
classes. I add rar files in my plug-in project->properties->Libraries. I
have tried to export it in "export and order" but the result is the same.
I think itŽs not a problem of the dependencies of the project because with
Eclipse 3.1 the project hadnŽt problems.
Re: Problem with XMLConfiguration [message #200077 is a reply to message #200054] Sat, 17 March 2007 12:23 Go to previous messageGo to next message
Fran,
Maybe you should check the Runtime tab to see if the packages need to be
exported using the Add... button.
> another classes. I add rar files in my plug-in
> project->properties->Libraries. I have tried to export it in "export
> with Eclipse 3.1 the project hadnŽt problems.
Re: Problem with XMLConfiguration [message #200218 is a reply to message #200077] Sun, 18 March 2007 09:42 Go to previous message
ItŽs not the solution because I canŽt add packages from the JAR file. I
will let it because I think itŽs very strange. I will return to Eclipse
3.1 and all solved.
THANK YOU SO MUCH!
Previous Topic:Build numbers
Next Topic:Java editor mark occurrences colour
Current Time: Sat Jul 26 08:32:27 EDT 2025
Powered by FUDForum. Page generated in 0.08318 seconds
