| Code Assist lag [message #199984] |
Fri, 01 April 2005 10:26  |
Originally posted by: lapwah.lee.gs.com
On the whole, my experience with Eclipse has been very good but there is
one thing that drives me absolutely crazy. It's enough to make me want to
think about switching to Intellij.
When using Code Assist, Eclipse will time out for a good 3-5 seconds,
sometimes longer. Originally I suspected that it was the network drive
but moving to the local drive has been no help. Upgrading to 3.1 also
doesn't help. My work colleagues experience the same problem.
It's a huge productivity drag when you're on a developing tear only to be
throttled by the IDE.
| Re: Code Assist lag [message #200137 is a reply to message #200115] |
Mon, 04 April 2005 09:29  |
Just adding to the other comments: There is a debug flag you can enable
which will then cause eclipse to write out timing data for code assist
to the console:
start eclipse like this:
$ eclipse -debug <optionsfile> [other parameters]
where <optionsfile> is a file containing the following line:
org.eclipse.jdt.ui/debug/ResultCollector=true
Including the output in bug reports helps us to track down the culprit
for slow code assist.
Also see https://bugs.eclipse.org/bugs/show_bug.cgi?id=86579 for another
bug dealing with slow parameter guessing.
-tom
Philippe Mulet wrote:
> Just to confirm. CodeAssist is meant to answer completions within half a
> second normally.
> If you are experiencing slower responses on a standard machine, then we need
> to get testcases for these.
> Things which could also hurt: antivirus ? memory ? VM ?
> "David Audel" <david_audel@fr.ibm.com> wrote in message
> news:d2qvm5$h2g$1@news.eclipse.org...
>>Hello, could you fill a bug report in JDT/Core
>>(https://bugs.eclipse.org/bugs/) with a test case or a description of
>>the completion context (workspace configuration, source code, ...) ?
>>Code assist is slow for all completions in your workspace ?
>>Code assist is slow only for some specific completions ?
>>Code assist is not slow every time for the same completion ?
>>Thanks,
>>David
>>>to think about switching to Intellij.
>>>be throttled by the IDE.
FUDForum. Page generated in 0.20863 seconds
