Home » Language IDEs » ServerTools (WTP) » Error while creating Dynamic Web Project
Error while creating Dynamic Web Project [message #199736] Fri, 14 September 2007 07:13
Hello All,
I am getting following error while creating a Dynamic Web Project.
The stack trace is as follows:
!ENTRY org.eclipse.wst.xml.core 4 4 2007-09-14 16:37:16.077
!MESSAGE Resource '/Test/WebContent/null' does not exist.
!STACK 1
org.eclipse.core.internal.resources.ResourceException: Resource
org.eclipse.core.internal.resources.Resource.checkExists(Res ource.java:310)
org.eclipse.core.internal.resources.Resource.checkAccessible (Resource.java:193)
org.eclipse.core.internal.resources.Folder.assertCreateRequi rements(Folder.java:32)
at org.eclipse.core.internal.resources.Folder.create(Folder.jav a:88)
at org.eclipse.core.internal.resources.Folder.create(Folder.jav a:118)
org.eclipse.wst.xml.core.internal.emf2xml.EMF2DOMSSERenderer .createDocument(EMF2DOMSSERenderer.java:161)
org.eclipse.wst.common.internal.emf.resource.EMF2DOMRenderer .createDOMTree(EMF2DOMRenderer.java:127)
org.eclipse.wst.xml.core.internal.emf2xml.EMF2DOMSSERenderer .createDOMTreeIfNecessary(EMF2DOMSSERenderer.java:183)
org.eclipse.wst.xml.core.internal.emf2xml.EMF2DOMSSERenderer .doSave(EMF2DOMSSERenderer.java:239)
org.eclipse.wst.common.internal.emf.resource.TranslatorResou rceImpl.doSave(TranslatorResourceImpl.java:180)
org.eclipse.wst.common.internal.emf.resource.TranslatorResou rceImpl.save(TranslatorResourceImpl.java:160)
org.eclipse.wst.common.internal.emf.resource.ReferencedXMIRe sourceImpl.saveIfNecessary(ReferencedXMIResourceImpl.java:27 2)
org.eclipse.jst.j2ee.web.componentcore.util.WebArtifactEdit. addWebAppIfNecessary(WebArtifactEdit.java:441)
org.eclipse.jst.j2ee.web.componentcore.util.WebArtifactEdit. createModelRoot(WebArtifactEdit.java:499)
org.eclipse.jst.j2ee.web.componentcore.util.WebArtifactEdit. createDeploymentDescriptor(WebArtifactEdit.java:650)
org.eclipse.jst.j2ee.web.project.facet.WebFacetInstallDelega te.execute(WebFacetInstallDelegate.java:99)
org.eclipse.wst.common.project.facet.core.internal.FacetedPr oject.callDelegate(FacetedProject.java:1201)
org.eclipse.wst.common.project.facet.core.internal.FacetedPr oject.modifyInternal(FacetedProject.java:394)
org.eclipse.wst.common.project.facet.core.internal.FacetedPr oject.access$2(FacetedProject.java:288)
org.eclipse.wst.common.project.facet.core.internal.FacetedPr oject$1.run(FacetedProject.java:270)
at org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1797)
org.eclipse.wst.common.project.facet.core.internal.FacetedPr oject.modify(FacetedProject.java:280)
org.eclipse.wst.common.project.facet.ui.ModifyFacetedProject Wizard.performFinish(ModifyFacetedProjectWizard.java:373)
org.eclipse.wst.web.ui.internal.wizards.NewProjectDataModelF acetWizard.performFinish(NewProjectDataModelFacetWizard.java :292)
org.eclipse.wst.common.project.facet.ui.ModifyFacetedProject Wizard$2.run(ModifyFacetedProjectWizard.java:261)
org.eclipse.wst.common.project.facet.ui.ModifyFacetedProject Wizard$3.run(ModifyFacetedProjectWizard.java:275)
org.eclipse.jface.operation.ModalContext$ModalContextThread. run(ModalContext.java:113)
!SUBENTRY 1 org.eclipse.core.resources 4 368 2007-09-14 16:37:16.077
!MESSAGE IWAE0017E Unexpected IO exception occurred creating xml document
!ENTRY org.eclipse.wst.xml.core 4 4 2007-09-14 16:37:16.108
!STACK 1
org.eclipse.wst.common.internal.emfworkbench.integration.Edi tModel.primSaveResource(EditModel.java:1299)
org.eclipse.wst.common.internal.emfworkbench.integration.Edi tModel.saveResource(EditModel.java:1330)
org.eclipse.wst.common.internal.emfworkbench.integration.Edi tModel.primSave(EditModel.java:1265)
org.eclipse.jst.common.jdt.internal.integration.JavaArtifact EditModel.primSave(JavaArtifactEditModel.java:132)
org.eclipse.wst.common.internal.emfworkbench.integration.Edi tModel$1.run(EditModel.java:372)
org.eclipse.jst.common.jdt.internal.integration.JavaArtifact EditModel.runSaveOperation(JavaArtifactEditModel.java:136)
org.eclipse.wst.common.internal.emfworkbench.integration.Edi tModel.save(EditModel.java:375)
org.eclipse.wst.common.componentcore.ArtifactEdit.save(Artif actEdit.java:409)
org.eclipse.jst.j2ee.web.componentcore.util.WebArtifactEdit. createDeploymentDescriptor(WebArtifactEdit.java:651)
!SUBENTRY 1 org.eclipse.core.resources 4 368 2007-09-14 16:37:16.108
I am using Eclipse 3.3 Build ID I20070625-1500 with WTP 2.0 Build ID
200704060120.
Can any please throw me some light on why this error is occurring?
Thanks in advance..
Jugal
Previous Topic:Setting the default value of an element in the xsd schema editor
Next Topic:Issue EARExport task Eclipse-3.3-jee-europa
Current Time: Sun Jun 22 13:41:10 EDT 2025
Powered by FUDForum. Page generated in 0.05467 seconds
